High sensitivity speakers
KeithV
KeithV Posts: 107
edited February 2007 in 2 Channel Audio
Hey gang,
I was wondering if anyone has any suggestions on some speakers for 2 channel that can be driven with 10-20 watts of tube power, or ~25 watts of solid state.
Size is not a concern... price is :) I'd like to only invest $100-$150 for the pair, so I'm looking something I can find used.
The only reason I'm not ponying up for some SDAs off the bat is because I am doing the whole "start small and go from there" route... Even if I bought a pair of high end speakers, I wouldn't be able to buy the amp, source, preamp, controls, ect to actually make it worthwhile.
Post edited by KeithV on
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited January 2007
    In my experience, it has always served me better to buy what I really wanted the first time.....
  • TroyD
    TroyD Posts: 13,083
    edited January 2007
    I've found that MOST speakers, anything in the 88-89db 1W/1M can be run on that sort of power.
    Hell, Hoosier used to run his 1.2tl's on a NAD 3020 integrated.
    BDT
  • madmax
    madmax Posts: 12,434
    edited January 2007
    Size is the problem with getting high efficiency. The bigger the driver and box, the more eff you can get. I'm thinking if you want something fairly eff I would suggest looking through the audio asylum in the high eff section and make yourself familiar with whats out there or what you can build given your price range. There are fostex drivers which are 97 or higher eff which can kick some butt and do it with quality in the right enclosure. That is enough eff to drive with the little sonic impact amp for $25 and you could end up with audiophile sound at the same time with a decent cd source.
    madmax
    Vinyl, the final frontier...
  • KeithV
    KeithV Posts: 107
    edited January 2007
    Currently I have an old Pioneer integrated that does 25wpc.. I am also thinking about buying an integrated tube amp from this stereo repair shop around the corner. It's from a 40s RCA big console stereo. The owner cleaned it up really nice and only wants $50 for it. Does 15wpc.
  • hoosier21
    hoosier21 Posts: 4,413
    edited January 2007
    BDT
    yes I did,
    in a pinch, I even drove a pair of Carver Amazings Plats with an Adcom 535
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Crispycircuit
    Crispycircuit Posts: 49
    edited January 2007
    It depends on how loud you like your music and how big is your rooom... Some speakers don't need much wattage for a decent volume but really demand power when trying to get higher SPL. I'd watch Ebay and buy a name brand like JBL. This way you can get your money back when you want to up grade. Ebay has a hugh selection. Just watch the shipping charge and the sellers feedback. I've also heard several B & O speakers that sound great. Some of these old speakers still compete with the new stuff. This is a way to work your way up the sound ladder and have some and learn. Even the guys with the finest system money can buy have a second system to play with. Audiophiles are never satisfied. Speaker wires, interconnects, cd mats, 20 amp dedicated breaker circuit, bass traps, voltage regulators, and on & on...... You can have more fun on the cheap with used gear and get a fine sounding system... Enjoy the trip.......
  • Toka78
    Toka78 Posts: 192
    Both Omega and Zu make high eff. speakers, but they ain't cheap.
  • unc2701
    unc2701 Posts: 3,587
    Pick up a pair of Fostex FE166E drivers from madisound:
    http://www.madisound.com
    They're not the best in a bass reflex box, but it's a good starting point for high eff. speakers... Plans here:
    http://www.madisound.com/pdf/fostexdrivers/FE166E.pdf
    plus tons more info if you google it.
    Backburner:Krell KAV-300i
  • Crispycircuit
    Hey Unc, Geez now you got me hooked. I got to check these out. Looks like a great project to go with my tube gear. Thanks for the info.......
  • unc2701
    Yep, they're cheap, fun and sound pretty damn good. Plus there's a huge community of DIYers out there... give 'em a shot.
  • ohskigod
    ohskigod Posts: 6,502
    Any Bozak would fit that bill. The Bozak Symphonies had 2 12" woofers, a 6" mid and 8 tweeters per channel, an sounded wonderful on 8 watts of power from the little Radii I had (and Fireman32 currently uses(, as well as 10 or so a channel from a Sophia electric baby amp.
    there are smaller bozaks, but not much smaller.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
