TV into 5.1 DD?
MrNightly
MrNightly Posts: 3,370
edited March 2007 in Speakers
So the Super Bowl is Sunday... the party is happening at my place, and I want to hook up my HT into the TV. How do I do this?
Currently, I'm just running the TV on stereo and the little built in speakers. I know it must be possible to hook my 5.1 Dolby Digital up right? I tried searching for this, but didn't really turn much up.
Show me the magic, so I can FEEL the big game... :D
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
Post edited by MrNightly on
  • Lsi9
    Lsi9 Posts: 616
    edited January 2007
    If your TV doesn't have an optical or coax out then look for it in back of the cablebox, if not call the cable company for a digital box!
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Willow
    Willow Posts: 11,060
    edited January 2007
    MrNightly..do you have HD ? if not I'm sorry to tell you that you most probably will not be able to get it in DD. The only DD stuff I watch is in HD.
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    does your TV have a optical output? if so run that to your receiver.. OR if your cable box has a digital output, run that to your receiver... and as long as you are watching a HDTV signal.. it should be in dolby digital.
    PolkFest 2012, who's going>?
  • danger boy
    edited January 2007
    OR if your TV doesn't have a optical output, then you can run a left and right RCA cables from the audio out to your receiver. it will only be in dolby pro logic (II)(X), but it still may sound pretty good. this is a lesser sound quality.. but on my old Marantz i did that.. and on the TV I was able to select surround sound matrix sound.. and once it ran into the receiver.. it sounded pretty good.. make sure your subwoofer is turned on..
    have fun.. games in surround sound sound fantasic.
  • MrNightly
    edited January 2007
    Hmm, first off, don't have cable.
    Second off, no Coax or Optical cable anywhere in site on the back of the TV. It's not a HDTV either. So is it not even worth trying to hook up thru the AVR? Interesting.
    So you are saying I need a new TV? ;) Let me tell the wife real quick..
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • MrNightly
    edited January 2007
    I could try the L/R audio out to TV in on the AVR. It's gotta sound better than just the little speaks on the TV.
    Hang on, I've got some testing to do... :D Thanks!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • danger boy
    edited January 2007
    Once you hook thing up this way.. turn off the internal TV speakers.. there should be a setting in the TV menu for this..
    good luck.. i have a feeling.. this should work for you.. :D
  • Lsi9
    Lsi9 Posts: 616
    edited January 2007
    Hmm... without the HDTV or DD, IMHO its not worth connecting & watching through speakers
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • MrNightly
    edited January 2007
    It worked!
    Just ran the old red/white cables from audio out to TV in on the Denon. I have about 8 different settings to play with, (Cinema, Game, Direct) 5.1/7.1 sounds the best/loudest. I wouldn't say any of them are super clear, but they do sound slightly better than the tv speakers.
    Thanks Danger! It'll do, but I fear there won't be much bass during the game. I was hoping to FEEL the hits, but probably not huh? Ohtwell.
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • danger boy
    edited January 2007
    MrNightly wrote:
    It worked!
    Cool, glad it worked for ya.. it's the closest you'll be able to get to DD without having the needed equipment. I used to listen to TV that way for a couple years. It was fine. although.. to me.. dolby prologic sounded the best.. does your TV have matrix surround sound? if so.. enable that.. i prefer that over any of the AVR dsp's. but whichever sounds best to your ears.. and maybe you can crank the sub up a few notches.. just for the game of course. ;):p
  • phileth
    phileth Posts: 22
    edited March 2007
    Hey Guys. I asked this question a while back and just wanted to confirm it based on some new information that I received.
    Just for some background: I currently have one of the old Samsumg Directv DVR's with Tivo. The optical digital audio is run out to my AVR. I do not have HD service, just standard definition.
    Here is my question: Why can I not receive TV shows in Dolby digital 5.1? For example, C.S.I. (among many others) on CBS is broadcast in dolby digital 5.1 as shown by the little symbol on the screen at the beginning of the show. However, my receiver does not pick up the signal, It is just in stereo.
    Someone on here replied that you have to have HD service to get the Dolby Digital 5.1. However, Directv is now advertising the new Directv Plus DVR (Not HD) with Dolby Digital. Why would this be different than the older Directv DVR with Tivo?
    I called Directv and they said that whatever signal they receive from the "broadcast center", that is what they pass on to the customers. That didn't really make sense to me. If that is the case, who is getting shows in dolby digital?
    Thanks for reading. Any help would be appreciated.
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2007
    I am, through an off-air HDTV antenna. When I tried connecting my AVR to my HD Cable, most shows were being broadcast in DD2.0.
    However, since my TV has a built-in HDTV tuner I just connect the optical out from my TV to the receiver. This provides DD5.1 on all HDTV channels.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • danger boy
    edited March 2007
    you need a HD receiver to get 5.1 surround sound from programs.. even if they say.. 5.1 surround.. your box unless it's high def, will only give you DPLII not 5.1
    trust me. I've checked into it many many times. the only other thing you can do is mount your own over the air antenna outside on your house/garage and receive high def programming that way. i to do and I can watch anything over the air in HD and DD 5.1 surround. problem solved. BUT, i can't record HD doing it this way. as i'm bypassing the cable box to get HD and DD 5.1
  • danger boy
    edited March 2007
    Bingo. that is exactly what I do too. :D
  • Willow
    edited March 2007
    it sucks thinking you have a "digital box" well that's we we moved up to the HD box as well as for the fact we bought an HDTV.
    The base Digital box can be hooked up via digcoax or toslink but there is no way you'll see DD5.1 on the display of your receiver. You need and HD box or an HD over air antenna.
  • phileth
    phileth Posts: 22
    edited March 2007
    Thanks for the info. I've been very happy with directv, but this seems like false advertising to me, especially since they are now advertising the directv plus dvr as being dolby digital 5.1 ready. All you need, they say, is surround sound equipment.
  • nebborjk
    nebborjk Posts: 425
    edited March 2007
    Phileth,
    The newer Mpeg4 STB's that DirecTV offers may very well offer DD5.1 with SDTV (I don't know), however it appears that you have an older Mpeg2 STB. This could be where your problem lies.
    Proud SOPA Member since 2005!
