fried adcom gfa555
ronnie
ronnie Posts: 150
edited January 2007 in Electronics
yup...its gone. no power, no lights, no sound....now i can get my hands on a gfa 555 11...i heard its newer. will it have the same exact tonal qualitys as the original gfa555. i heard the power supplys are diffrent
Yamaha RX-V2600
Adcom GFA555 x 2 :D
Yamaha CD685 cd changer
Yamaha Dvd c950 dvd changer
Polk RTi12 mains
Polk CSi3 center
Polk psw303
Polk RTi6 (surround and surround back)
Acoustic Research 12in 200 watt sub(8 years old and still hits hard:D)
WindyWillys cooling fan (works great)
Mitsubishi 52in big screen
blue jeans cables
AR interconnects
  • dkg999
    dkg999 Posts: 5,647
    edited January 2007
    Did you check the fuse?
    DKG999
  • ronnie
    ronnie Posts: 150
    edited January 2007
    it blows them as soon as i hit the power switch
    Yamaha RX-V2600
    Adcom GFA555 x 2 :D
    Polk RTi12 mains
    Polk CSi3 center
    Polk psw303
    blue jeans cables
    AR interconnects
  • dkg999
    dkg999 Posts: 5,647
    edited January 2007
    Yep, you officially have a problem :( Adcom's are pretty easy for tech's to work on, if you have any local electronic repair shops you may be able to get it fixed pretty easily and hopefully cheaply.
    DKG999
