newbie question: Denon 1907 or Onkyo 604
anujit.d
Hi,
I have decided on getting myself a Monitor 5.1
M50s, M30s, CS1 and a PSW10.
I have not been able to decide which of the 2 receivers would be best suited
Denon 1907
Onkyo 604.
My room area is 10' X 15" ( distance between the M50 in the front and the M30 at the back is 10').
My movies / music preference is about 60:40
I am keen on the 1907 because of the bi-amping facility in Denon, which would allow clarity at low - medium volumes,..I hope I am making the right choice.
Denon 1907
Onkyo 604.
Post edited by anujit.d on
You may also want to consider a H/K receiver. The have a laid back sound, that should compliment those speakers very well. Don't let the lower wattage ratings fool you. They use high current amplifiers that more than make up for the rating.
