H/K EasyEQ
Lowell_M
Lowell_M Posts: 1,660
edited February 2007 in Electronics
Ok. I'm frustrated again. I moved furniture around a little bit and thought I would recalibrate and rerun the EasyEQ....just because. Well now the problem I originally had before I last calibrated came back... Highs are crystal clear, bass is tight and digs deep...sound is generally warm or laid back, but vocals, whether in 2 channel or center stage in a movie sound like they are coming from behind the wall (sort of) There is a "mid bass bloat" as I called it before.
Anyway.... I found a great thread here that linked somewhere else that told how to completely reset the H/K then a modified easy set routine (volume different from the directions and mic in a more specific location for near field measurements), but I can't find it!! Anybody know what I am talking about?
By the way.... the DTS track in Pearl Harbor is awesome.
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
Post edited by Lowell_M on
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2007
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Lowell_M
    edited January 2007
    AndyGwis wrote:
    Andy, This link won't work.:confused: If you can fix the link, you da man!! :cool: I thought I could probably count on you to come through with some H/K help.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    You can do a much better job with an SPL meter, and manually adjusting Each speaker with the EZ option.
    Ben
    Ben
  • Lowell_M
    edited January 2007
    ben62670 wrote:
    You can do a much better job with an SPL meter, and manually adjusting Each speaker the with the EZ option.
    Ben
    I'm not talking about simply spl calibration. There is also a room EQ function that evidently didn't go so well when I ran the test. It normall does wonders for bass equalization.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • AndyGwis
    edited January 2007
  • Lowell_M
    edited January 2007
    AndyGwis wrote:
    Exactly what I was looking for. Thanks Andy.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • ben62670
    edited January 2007
    I also have an HK AVR but I thought the EQ function only worked on the center channel?
    Ben
  • AndyGwis
    edited January 2007
    No Benji, she works all the way around. I find it's a feature that works very well not only for channel / distance level, but also EQ based on room characteristics.
    Go through following the link I provided above and let us know if it makes your system sound any better, worse, or same.
    Good luck.
  • starchaser
    starchaser Posts: 354
    edited January 2007
    Thanks for the link again!
    "There's a lot of places driving up and down I-95 that smell like ****" F1Nut
  • Lowell_M
    edited January 2007
    Good luck.
    I just recalibrated to that guys guidance (minus the tripod) and cured my issues. I'm really impressed with how it tightens the bass up.
    I'm going to borrow somebody's tripod and try again to see if everything gets set the same.
    The biggest different I was was between holding the mic 3' above ear level (which is what the software recommends) and at ear level. I also need to get my hands on a meter to measure where I am really at, but there was a 3db difference in settings of the channels.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Ern Dog
    Ern Dog Posts: 2,237
    edited January 2007
    After reading that link again, I decided to order the mic & extension arm from HK (52$). When I bought my HK it was a floor model and didn't include it. I'll post my results soon. I love the idea of it having a built in room adjustment EQ.
  • Ern Dog
    I just completed the easy eq calibration with the mic and noticed 2 dramatic differences.
    1) The low bass is gone. Songs that usually rattled my house are now much tamer. Not sure if I like that or not- I think Not .... but will sit with it for a few days to see. Also it set my sub to +10 db. I think I'll turn the gain up on the sub and re-run it.
    2) There is less bright glare on the highs. I definetly like this.
    With the automatic eq settings, it is all or nothing. I'll give it a few days to let it gel.
  • Lowell_M
    I ran mine with the sub gain at 12:00. It set my sub at -4. After running the setup, you can go in a tweak to your liking and all that changes is what you tweak. Mine set the crossovers to my RTi70's at 40hz, which I promptly raised to 80. Then I raised the sub setpoint 5db higher, since I like a little heavier bass. What resulted was very tight, accurate bass from the sub that blends very nicely with the crossover point of the RTi's.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • Ern Dog
    Well it has only been a day, but I can already tell that music sounds smoother. The mids are more present and bright highs toned down and the bass is more controlled. I tweaked my sub so that I still get the lows that I love- it is just tighter now. My sub gain is also at noon.
    The internal EQ has only peaked my interest in knowing what an external 20 band professional EQ would be like. :eek:
  • Ern Dog
    Question: Why does the HK manual say to run the ez eq at volume -28, but the on screen display says to set volume at -35? This is weird- I used -35.
  • Lowell_M
    :confused: ????I've used both. I thought i got better results from -28, but who knows what difference it makes.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
