Denon AVR-4806CI Opinions?
hmhoshino
hmhoshino Posts: 4
edited January 2007 in Electronics
What do you think of this receiver to replace my Denon AVR-5700? I am getting a little frustrated with the lack of hook ups for HD, since I have a Mitsubishi WD-57731 1080P tv. I also a Xbox 360 and plan to get either a Blu-Ray or HD DVD player. I have a complete set of home theater speakers.
Will I be able to set up my system with the on screen menu in HD or will I need to switch back to normal viewing. I like the idea of having a touch screen remote that will be easy to operate like my touch screen GPS in my car.
Henry
Post edited by hmhoshino on
  • DAMCB
    DAMCB Posts: 35
    edited January 2007
    Hi Henry-
    Denon will update all of their upper level receivers including the 4806CI this year(4808CI?) according to info released at CES. The updates include HDMI 1.3, onboard decoding for the new DTS and Dolby lossless HD audio formats, pc setup, HD Radio, and other "goodies". I want to upgrade my Denon 3805 that I'm using as a prepro when these are released.
    Checkout audioholics and secrets CES coverage for more info. If you still want the 4806 the price should fall with the new model release.
    Don
  • hmhoshino
    hmhoshino Posts: 4
    edited January 2007
    Don;
    Thanks for the reply. I can get it for $2795 thru AAFES including shipping, since I am retired Army. It is already on the AAFES web site, unlike some of the local high end home theater stores around here.
    It sure sounds tempting, but is there something better?
    Or would I be better off going with a Pioneer Elite VSX-84Txi? I really don't need the ability to have home theater in three rooms like the Denon.
    Henry
  • Porter
    Porter Posts: 34
    edited January 2007
    There's *always* something better... but the Denon is very very good.
  • DAMCB
    DAMCB Posts: 35
    edited January 2007
    Henry;
    That sounds like a good deal, I think that the 4806CI lists for $4000. There is a large thread called "The Official Denon AVR-4806 Thread" at avsforum that has a great deal of information from owners of this model.
    Don
  • hmhoshino
    hmhoshino Posts: 4
    edited January 2007
    Don;
    I just have to see it in person and check how easy it is to operate before I purchase it. I like the quality of Denon so I am a bit partial to Denon, since I had no trouble with my receiver.
    I didn't know AVS had a forum on the 4806, and I need to check that out.
    Thanks,
    Henry
  • DAMCB
    DAMCB Posts: 35
    edited January 2007
    Henry- I don't know if you looked at the Owner's Manual pdf for the 4806CI on Denon's site- I printed this out, less the remote codes, when I was researching this model. There are a lot of features that are not listed in the reviews. Don
  • Lowell_M
    Lowell_M Posts: 1,660
    edited January 2007
    Buy a lower powered Dennon with the same features and buy external amps if you are going to sink that much money into it. You'll be happier with the sound.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • hmhoshino
    hmhoshino Posts: 4
    edited January 2007
    Don;
    I tried to print a copy of the manual from the Denon site, but for some reason it wouldn't let me. But the 4806CI sure sounds great to me.
    A;
    I have some space issues and my Salamander stand is full, and I don't want or need to get components. Besides I am not that much of an Audiophile.
    Henry
  • Porter
    Porter Posts: 34
    edited January 2007
    I would buy a B&K Components AVR505 S2 if I was going to spend that kind of money.
    No HDMI though... I guess you have to choose your passion. The Denon stuff is great at video switching. They are also quite good on the audio side for a consumer receiver. There is better stuff out there from a purist audio standpoint though... which is where I tend to gravitate.
    If you're not really into the audio thing then the Denon is about the best option on the market.
