need last advise before upgrade.
MSALLA
MSALLA Posts: 1,602
edited January 2007 in Speakers
I'm getteing ready to pull the trigger and get th Lsi15's and an amp. Reading different threads, I see these are very placement sensitive. I have one place I can put these speakers. They will go on either side of my TV approx. 5-1/2 feet from each other, set twords the corner but the sides will not be blocked. The room is 12 x 25 and I will sit about 22 feet from the speakers face.
I love the way they sound in the store, but will my placement be an issue?
This is my NEXT to last;) upgrade. In the end the set-up will consist of the 15's of an amp, lsic off an amp, lsi7 rears off recv., my sub will be done as soon as work lets up. I'm just trying to make sure I'm heading in the right direction considering the short comings of the room.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Michael, I would think that you would be siting to far away...Room treatments...such a long room... Sounds like you are going to have fun!
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2007
    AT 25 ft long, it sounds like your room has long-comings, not short-comings.
    You should have a great setup going once the Lsi15s are in and the sub is completed. Looks like you've been prudent in your efforts, and I'm sure they'll be paying off soon.
    Where'd you go for the 15s, if you don't mind me asking?
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    I agree. Is there a way to sit closer? If not, your surround sound won't sound surround. Also, can you spread the speakers out more than 5.5 ft.?
    Got any pics of the room?
    "God grooves with tubes."
  • Monster Jam
    Monster Jam Posts: 919
    edited January 2007
    A bit off topic but one kind of amp are you considering? I am in the peripheral amp market and I have 4 hungry 15s and a C to drive. My HK is crying.
    Do you hear that buzzing noise? :confused:
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Glad to hear you are getting the 15's (and an amp). Are you getting a 3 channel amp (to run your future center off of) or just a two channel?
    Placement will not be ideal, but I assume that is similar to what the placement is with your 7's now so you should know what to expect. I have my 15's about 7 feet apart in the corner of the room with the backs almost touching the wall. (since they are facing out of the corner - the fronts are a foot or two away from the wall) It is not ideal, but I cross them over to my sub (which is equalized with a BFD) at 80hz so I don't get zinged to bad with extra bass energy.
    I would say you will be fine, but depending on how far the sides are from the side walls, you may not want to run them full range. (at least experiment)
    The amp you choose will make a big difference in the sound. What are you looking at?
    How are your 7's holding up, still enjoying them I assume? With that big room, you will notice more impact from the 15's. I sure did.
    Michael
    BTW - You can see my setup by clicking on the quote in my signature. It is about the same as what you are setting up.
  • pblanc
    pblanc Posts: 261
    edited January 2007
    Maybe I was just lucky, but I haven't noticed any placement problems with my LSi15s. I too found that about 7 feet between speakers sounded best.
  • sickicw
    sickicw Posts: 456
    edited January 2007
    You can always fix bad speaker placement with bass panels. I have the lsi9s that i have to place about 15 inches off the wall which makes the bass sound boomy. After adding bass banels between the wall and my speakers, they now sound a lot tighter. If the 15s are too close to the walls, just add some bass panels... my favorite are the mondo traps from realtraps.com
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2007
    :D WAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!:D :D Classic, absolutely classic!:D
  • MSALLA
    MSALLA Posts: 1,602
    edited January 2007
    McLoki, still loving the 7's. they sound great but I think the 15's will fill the room nicely. I'm looking for used amps. If I don't get a 3 channel, I will probably go with a used Parasound and an Outlaw 2200 for the center.
    Andy, I'm looking for used 15's but if I don't find a good deal with in the next month, I will just hit Tweeter and buy new.
    Thanks for the input everyone.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Someone just posted adcom 565 monos in F/S...
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    What is your budget for an amplifier?
    Michael
  • MSALLA
    MSALLA Posts: 1,602
    edited January 2007
    In the 1000.00 range for used. I am a deal hunter though so I'll take my time and find a good deal.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Sunfire Cinema Grand - 200x5 - $995
    Aragon 8008 - 200x3 - $1100
    Aragon 8008 - 200x3 - $1095
    Adcom GFA-7500 - 150x5 - $625
    There is also a cinepro similar to mine on sale for $1500. I did not link to it since it is so far over your budget, but they don't come up for sale that often and I can safely say it may be the last amp you need to buy. 350x6
    No affiliation to any of the amp sales, just wanted you to see what was available (for now and from one place) in your price range.
    Enjoy and let us know what you end up with.
    Michael
  • MSALLA
    MSALLA Posts: 1,602
    edited January 2007
    Michael, thanks for the heads up. As soon as work lets up some I'm going to take the time to audition some before I commit to buying. There is a small shop not to far from me that sells used high end equipment I want to check out.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
