Which is better for tile floors? floor or front firing?
Dannieboiz
i have front firing NHT SubOne that I'm not really satisfy with @ certain seating area of the room. Are floor firing subs better for tile floors?
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Onkyo TX-SR875
Velodyne DPS-12
Post edited by Dannieboiz on
What is the problem..not enough..too much..sounds boomy...ect?:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon) -
There are a lot of blind spots around the room where I it's lacking bass. I was hoping for an evenly distributed sound throughout a small room. Roughly 15x15. The box is sitting @ the rear corner of the room.Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
MartinLogan Dynamo 10 -
Sounds like you have standing wave issues. A square room is almost the worst acoustic environment. You might look into bass traps in the sub section.
I had a Velo that was front firing and my VMPS is front fire no probs.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
bass trap? what's that?Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
It is a culmination of materials and design to "soak up low,mid or high freq's.
A basic understanding of what happens: a "wave" is moved forward bounces off a wall and meets another wave and they cancel each other out.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
did a quick search and it looks like I need to slap some metal sheets behind my walls? Any quick and easy way to do this?Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
no not metal!....Perhaps someone can post the thread BASS TRAPS. I do not know how to do this.Dannieboiz wrote:did a quick search and it looks like I need to slap some metal sheets behind my walls? Any quick and easy way to do this?
Or go to forums. go to DIY and search bass traps.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
ok I'll search for it. No biggy, i need to upgrade my subs anyways....Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
SLOCOOKN wrote:It is a culmination of materials and design to "soak up low,mid or high freq's.
This action will result in a loss of bass freq's. A bass trap will absorb the low freq. and you will get a better sound. Most traps are made up of fiberglass.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
Dannieboiz wrote:ok I'll search for it. No biggy, i need to upgrade my subs anyways....
If you are going to be in the same room. A bigger or better sub won't help!
Spend the money on room treatments and you will be better served.
A good sub in a better room is better than a great sub in a bad room! REALLY!
It would not take much! At least consider it.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
my SubOne is giving up on me slowly. It creates this annoying hum with our without signal. I have to throw them out either way.... Also I don't want to fix any structure of the house improve the subs. Significant other is gonna kill me.Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
Dannieboiz wrote:my SubOne is giving up on me slowly. It creates this annoying hum with our without signal. I have to throw them out either way.... Also I don't want to fix any structure of the house improve the subs. Significant other is gonna kill me.
Don't give up yet! That hum might be ground loop. It is fixable.
The bass traps are not a construction effort. (the can be if you want)
Your wife could pick out fabric for the covers. It's a win win.
If you don't like it that is ok.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
Nordost RCA
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
I've moved the sub to another room total away from ANY thing that cause the ground noise but still there. The amp may have water damage cause my dump house/babysitter be cleaning my floors and shoving the damn mop all over my grill I can see obvious water damage in the front of the cloth.Sammy UN55C6400
Onkyo TX-SR875
Velodyne DPS-12
