Ohms, Volts, Impedance -
phipiper10
phipiper10 Posts: 961
edited January 2007 in Electronics
Ohms, Volts, Impedance, oh my!
With my limited knowledge and some light reading I believe I'm ok with my latest purchase of the VPC passive pre. I'm just looking for any other advice/suggestions or confirmation that I'm thinking about this correctly.
cdp Output Power: 2.2V (don't know the output impedance -can't find it anywhere)
AMP Input Impedance/Sensitivity: 33k Ohms/1 volt
Interpreting simply in terms of volts seems pretty straight forward - have enough to power amp but don't increase volume on pre past equivalent input voltage of amp. ??
I'm going with the basic principals found in the link below. My only concern is not knowing output impedance of the CDP. Do I assume since it's 2.2v that I won't have a problem? My connects are 1m or less.
http://www.decware.com/paper55.htm
Thanks,
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    You'll be fine.
    "God grooves with tubes."
