Help
I currently have a Yamaha HTR-5740 receiver and am deciding on whether to get the rti8's or 10's. Will my receiver be powerful enough for the 2 models? If not what would be a good receiver to get.
Post edited by PolkFan1 on
Anyone?
What is the AVR rated for?
What will you be using it for?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Your receiver looks to be rated at 85 watts x 6 channels. The amp sections on the Yamahas are typically strong but I think you'll need a bigger receiver or amp to make the RTi8 or RTi10 sing. Something like the Yamaha RX-V2500 which seemed to pack some good power when I heard it at my friend's home.
If you are sticking with the HTR-5740, I think the current Monitor line is a better match. -
You can run the 8's off of what you have with no issues. I have a feeling the 10's will also be ok but you would get more out of them with something beefer. I would not but another receiver, but add an amp to the Yamaha. I think that unit has pre-outs.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
So I can just buy a seperate average amp rated at around 50 watts or so, and that will add on to the output of my current receiver? I only listen in stereo mode with a sub to music.
An amp will not add to your receiver, but be a substitute of your receiver amp. So a 50 watt amp is just a 50 watt amp, but know that 50 watts in an amp is more like 53 watts. Where a receivers 85 watts could be 35 watts in real life.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
