Need advice building a new 5.1 system
edited January 2007 in Speakers
My first post. Help, advice, cautions, etc, appreciated on setting up a mixed use 5.1 system.
ME: I’m a newbie. I only have one local hi-fi shop (which unfortunately caters to whole-house high-end systems) and don’t have the time to travel to hear speakers, so I’m depending heavily on Tweeter’s limited selection. I’m not somebody who will tinker and upgrade from year to year; I want to buy a system I can live with for some time.
SETTING & USE: a 20x24 living room with cathedral ceiling; probably 75% music (eclectic), 25% movies/tv. I’m much more concerned with music quality than home theater experience. Things rarely explode in the movies I watch. ;)
BUDGET: speakers + receiver/amp $5000 tops; I’d like to buy new; no gray market stuff.
SPEAKERS: I’m posting here because I thought the LSi15s were the best thing I heard at Tweeter in my price range. But I’m not sure I can integrate LSi15s into an overall system, given my budget. (The RTi10’s were decent too, given the price. Not as nice, certainly, but I could live with them.)
I’m thinking of:
L/R: LSi15s ($1500)
Ctr : LSiC ($700)
Surround: FXi5 ($600) ??
Sub: ???
Power????? I know almost nothing about receivers, amps, etc. I do know the LSi’s are power-hogs.
QUESTIONS:
--Can this be done for $5000? What components would fill out the system at this budget?
--Or am I better off scaling back to the RTi10s? (I’m concerned about room size.)
--Or is there a better system to consider in my budget and limited shopping options?
Thanks in advance.
Post edited by kokopup on
Welcome!
    edited January 2007
    Welcome; you have chosen the right speakers if music is your target. Unfortunately, not wanting to buy used limits you and your budget might be a bit short.
    In speakers alone you have $2800; add another $1000 for a good subwoofer (I saw your explosions comment...but if you really don't want to upgrade, you should buy something good....that's a big volume you need to fill).
    That leaves you with $1200 for receiver, amp (you'll need one for the LSi's), wires, interconnects, etc. Not enough if you buy new. One option would be, if you buy a good sub, you could maybe swap the 15's for the 9's, and have another $900 or so for electronics. There are many options out there; you can buy a low power Denon/Harman Kardon for around $500, and an Outlaw 7500 (5x200W) for $1600. You are above $5000, and you'd still need a couple hundred $$ to hook up everything.
    Buying used gives you more for your money; I used to think that buying new was the only way to go with electronics, but I've learned that you can buy good things in Audiogon or here.
    Good luck.
    SOPA
    edited January 2007
    Thanks. I am biased against buying used. (I have visions of someone blasting their speakers at maximum volume for hours on end at a keg party where folks are spilling beer on them:eek: ) I'm also leery of getting burned on a used sale. Any advice on improving my odds of success if I go this route?
    edited January 2007
    Keep in mind that the vast majority of used audio equipment (such as that which can be found on Audiogon), has been taken care of and pampered in ways that only the audio community are capable of. A "minor scratch" on a non-audio piece found on Ebay becomes a "severe festering gouge of epic proportions" to many involved with the used Audio market...
    That is to say, 9 out of every 10 of my purchases here on the Forum or on Audiogon have been in better condition than described...
    Ebay... it's a crap shoot. But if you want to save a ton of coin by going used (and you'll be glad you did because you'll get twice the system for the same amount of money), check out:
    www.audiogon.com
    edited January 2007
    Oh, oh. Sounds like more homework for me. :)
    Thanks.
    I'd still like to hear thoughts on powering LSi15s...new or used. Is there an on-line primer on amps/receivers I should read somewhere?
    edited January 2007
    Nearly everyone here will tell you to steer clear of a receiver and go with an amp/preamp combo. If you really, really have your eye on a receiver, make sure you get one with preouts so you hook up an amp to it.
    The thing is... the LSi15's are 4 Ohm speakers, and very few receivers are able to manage that load. Of course, there are exceptions (re: high-dollar exceptions....)
    edited January 2007
    If you really want to go with the LSi's, look at outlaw audio amp's. They are a great bang for the buck company. Very good equipment.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
    edited January 2007
    If he's going with about 75% music, I might steer him away from the Outlaws... IMHO
    edited January 2007
    WARNING: embarrassing newbie territory.
    Is this correct? A "receiver" is essentially a combo- amp/pre-amp + tuner.
    A "pre-amp" (a) provides switching from various sources and (b) processes the source signal for various formats.
    An amp boosts the signal to power your speakers.
    edited January 2007
    You're pretty much right on all accounts with the exception that the preamp also provides gain to the signal...
    edited January 2007
    Why?
    edited January 2007
    Because I believe there are many more amps that possess a bit more musicality than what Outlaw offers.... extremely popular among HT enthusiasts for the loads of clean power they provide on a budget -- not so much among the two-channel crowd.
    edited January 2007
    Okay, let's say I went the amp / pre-amp route. What, exactly, would I need to adequately power this system (LSi15s)? And--ballpark--how much $$ are we talking about here? (A quick look at amp prices left me with sticker shock, but I'm not really sure what specs I need). HTrookie mentions an amp/pre-amp combo that adds up to $2100. Is that typical?
    I'm still trying to judge if I'm in over my head here...and, if so, by how much :)
    edited January 2007
    kokopup just a suggestion...
    Instead of LSI15's($1200) look into the LSi9's($700).
    Prices are Acoustic Designs(where i ordered my LSI9's from,new/shipped)
    They are bookshelve speakers, but the money you save would ease up on the amplification you would be required to get and would also save you cash.
    With that money you can invest in a good SVS or HSU Sub.
    My original plan was to get LSi15's, but in the end i ordered LSI9's which were about 500 dollars cheaper for a pair vs the 15's.
    With the 500 i saved, I am putting it towards a new HSU sub personally.
    Because once you setup your 15's and get a good sub, you will apply a cut-off frequency to your fronts and moving all of that bass into your dedicated subwoofer, and essentially making the 8" Sub in the 15's obsolete...
    Click here To see My system
    Polk LSI15,LSiC, LsiFX, SVS PB-12 Plus/2, Blue Jean Cables,Onkyo Pro PR-SC885P, Earthquake Cin
    edited January 2007
    Hmmmm...interesting option. Why, then, does everything I read suggest that if your primary interest is music, floorstanding speakers is still the way to go. What am I missing?
    edited January 2007
    Well, floorstanders are the choice of many for music, including me I'd say, but it does not mean you cannot have a great system with bookshelves/monitors and a sub; it requires a good musical sub, and setting it correctly for a good blend. Floorstanders don't require all this hassle.
    SOPA
    edited January 2007
    Keep in mind i am not talking about getting a cheap 1-200 dollar sub.
    I am looking at geting the best sub i can afford
    The Two subs i am looking at are:
    http://www.svsound.com/products-sub-box-ultra1.cfm
    And
    http://www.hsuresearch.com/products/vtf-3-ho.html
    Where i am getting my choices from are from the Craigsub recommendation list
    1. $3200 JL Audio Fathom 113: 103 points.
    2. $4995 Velodyne DD-18: 100 points.
    3. $2100 ACI Maestro: 97 points.
    4. $2200 JL Audio Fathom 112: 95 points.
    5. $999 Hsu VTF-3 HO + Turbo: 94 points
    5a. $899 Hsu VTF-3 HO w/o Turbo: 92 points
    6. $1199 SVS PB12-Ultra: 90 points.
    6T. $1200 Axiom EP-500: 90 points
    7. $1199 SVS PB12-Plus/2: 87 points.
    8. $1099 Rocket UFW-12: 85 points (provisional)
    9. $199 Rocket X-Sub: 78 points
    10. $99 Rocket Tyke: 60 points
    http://www.avsforum.com/avs-vb/showthread.php?t=768150&page=1&pp=30
    With a really good sub i think that the 8" Sub in the LSi15's will essentially become obsolete....
    But read that thread and come up with your own impressions....
    If you are going to look at that list as well to purchase, just an FYI SVS is going to release a new Ultra series sub this year, which could blow away that list...
    http://www.svsound.com/news-news.cfm
Welcome!
Welcome!
