Line Conditioning
MillerLiteScott
I bought a multi-meter today for another project and just for kicks I thought I would test the outlet on the front of my Panamax M5100-EX and it read 123.
So I thought would try an outlet (originally for my sub) that is also fed by the same circuit as the power conditioner is plugged into and it read 123 again.
Next outlet, different circuit and original wiring in the house (built in 1948) and it read 120.
So I guess my power conditioner is not conditioning the power?
Any thoughts?
Any thoughts?
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
I think the term "conditioning" is more in relation to it removing AC noise, etc from the line before it gets to the components. It's more "stabilizing" when it keeps everything at 120V or so. Some of the high dollar (read expensive) units out there can maintain 120V when it dips below in the line. Guys? AM I correct in saying that?Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
avguytx wrote:I think the term "conditioning" is more in relation to it removing AC noise, etc from the line before it gets to the components. It's more "stabilizing" when it keeps everything at 120V or so. Some of the high dollar (read expensive) units out there can maintain 120V when it dips below in the line. Guys? AM I correct in saying that?
I believe you are correct SirCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
I guess it protects the equipment if the voltage drops to low or goes to high, because the manual says it will cut the power to the equipment if the voltage goes above or below a certain value, and will resume power when it returns to the safe value again.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
