6 x 9 help for '03 Civic
Hi Folks
I'm new here and would appreciate any advice some of the more experienced audiophiles could offer. I purchased a pair of MMC690 6 x 9's for the rear deck in my 2003 civic (coupe) and also a db6500 component system for the driver and passenger doors. I was told that they 6 x 9's would fit fine but now Crutchfield tells me that they likely won't... Haven't torn the interior apart yet and still waiting for the speakers to arrive.
I'm pretty sure the db6500 component system will fit fine, but concerned about the MMC690 6 x 9's.
Anyone out there have these installed in an '03 civic and if so how difficult was the installation?
Thanks for the help
Thanks for the help
Post edited by MadCad on
You will get a lot more and better responses in general if you post this in the car audio portion of the Forum..
Good Luck,
Josh -
Whoops! Coulda sworn I put it in the right forum. My Bad.
In any case it looks like the speakers will fit fine as long as they're top mounted.
