will this setup blow circuit breaker?
giff
giff Posts: 3
I've finally broken down and ordered a separate amp (Audiosource 300) to power my RTi 12's. (The receiver was clicking off at high volume levels, and I learned that the 12's really need more power than the Pioneer Elite 45tx can provide in 5.1.or more channels- it does fine in 2 channel mode with the 12's though) Anyway, the amp specs say it'll consume 1200 watts, The receiver consumes 3-400(??), the TV (A 64" pioneer RPTV) uses a couple 100 I assume, add in the DVD, Sat box, xbox etc and I think I might be exceeding the capacity of my 20 amp dedicated circuit. Do I need to add a separate circuit? How many watts can a 12 guage wire/20 amp circuit safely run? (20x120?)
Post edited by giff on
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    You will be fine. I can blow a 20amp circuit if I turn my amp on and off quickly about 4 or 5 times, but for normal playback, I have never had a problem. I think you will be fine. No need fixing problems that don't exist yet.
    Michael
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2007
    amps X volts = watts so a 20 amp circuit X 120 volts = roughly 2400 watts.
    You should rarely be reaching that type of draw with your gear even during peak power outputs.
  • Schwingding
    Schwingding Posts: 363
    edited January 2007
    Following Dennis' lead - watts/volts = amps. Find the max watts draw rating (not the output!) from your components and use that number divided by 120 volts, that'll tell you the max your equipment will draw and the max amps your circuit will have to deal with. You'll never reach max.
    BTW, a 20 amp circuit breaker will handle 30 amps for a few seconds before it trips. So even if you approached a 20 amp load, momentarily, you won't trip it.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • louthewiz
    louthewiz Posts: 581
    edited January 2007
    You are going to love that amp it is built like a tank and cranks like a bulldozer, and jr.com has them for $299.00 new.
    http://www.jr.com/JRProductPage.process?Product=4015069
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2007
    Michael
    Mike, I'm just curious, what would posess you to turn your amp on and off quickly about 4 or 5 times?
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    I was testing the trigger input to auto turn it on from my Pre/Pro. (never did get it to work correctly, oddly enough - the trigger input draws to much current (or voltage?) and wont turn on the amp. (I had a wall wart that when set to 12 volts would turn it on or off though....)
    It was odd, but now I just turn it on and off separately from my Pre/Pro.
    When I said turn it on or off quickly - it is turn it on or off more than 4 or 5 times in less than 1-2min. I think it is the inrush of power filling the caps that actually blows the circuit.
    Michael
  • louthewiz
    edited January 2007
    These control power strips are great just plug into thw wall,then plug avr or preamp into blue outlet and the amps into the red ones and when you turn the pre/pro on and off the amps will turn on and off at the same time,neat.
    Any of the first 3 on the top work the same.
    http://bitsltd.net/ConsumerProducts/buy.htm
    My gear,
    Acer PH530 720P PJ
    Yamaha HTR 5790
    Toshiba HD-A3
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    polk cs400 center
    polk RT400 mains
    Velodyne DPS-10 sub
  • hearingimpared
    edited January 2007
    I have a Monster HTS 5100 MKII that I purchased from Dane. I love it and got it for a good price too.
  • giff
    giff Posts: 3
    edited February 2007
    thank you for the tips
