How do you measure the DC offset of an amp
ben62670
ben62670 Posts: 15,969
edited October 2013 in Electronics
I need to know how to measure the DC offset of an Adcom Amplifier (GFA-585).
Thanks Ben
Ben
Post edited by ben62670 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2007
    I don't think an end user or consumer needs to be worried about that. An offset is measured in mv at a point between the output transistors, so this point can be before any final filtering circuit which to output terminals are connected to. If you suspect trouble woofer being pushed in or out with amp on, the amp needs service and I would do this ASAP before speaker damage.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2007
    Here is the best discussion I have found on the subject................http://audiokarma.org/forums/showthread.php?t=5634
  • ben62670
    edited January 2007
    Thanks for the link I am on it
    Ben
    Ben
  • scottyboy76
    scottyboy76 Posts: 2,905
    edited October 2013
    Never would have thought you could let an amp sit for ten minutes not hooked up.
    humpty dumpty was pushed
  • scottyboy76
    edited October 2013
    Is this a record? Diggin up bones.
    F1nut Posts: 51,794
    edited October 2013
    You can let a SS amp sit powered up without a load all day and twice on Sunday. Do NOT try it with a tube amp.
  • lanchile
    lanchile Posts: 560
    edited October 2013
    To check dc offset, do this:
    a) Turn on amp and let it warm up (half hour will do it)
    b) disconnect all inputs and speakers.
    c) Connect a multimeter (DC mv range) in the speaker terminals (+ - )
    d) it should read very low (10 mv or lower) the lower the better.
    I would consider a good and healthy reading in the 5 mv range, My diy amplifier is spot on the "0" mv.
    it will be a good idea to check the bias too, but this will need more steady hands and knowledge of what you are doing.
    PS: Every time you fix or upgrade an amplifier (change capacitors, resistors, transistors etc), you should check bias and dc offset.
    Make it simple...Make it better!
  • scottyboy76
    edited October 2013
    Bought a carver tfm35 yesterday, along with a ct-3, think i will check dc offset after first auditioning with my speaks.
    If this blows up, i will haunt you guys in the afterlife.
  • scottyboy76
    edited October 2013
    just checked the tfm 35, nothin, the needle moves slightly as the probes touch the terminals,.
  • scottyboy76
    edited October 2013
    after 45 minutes, i get 1mv on one channel, and 2mv on the other.
  • Glen B
    Glen B Posts: 269
    edited October 2013
    It should be the other way around. Whenever I acquire a used/vintage amp, I always check the DC offset first before hooking up to speakers, and an expendable pair at that. If the amp has a major problem, I don't want it hooked up to my good speakers.
  • scottyboy76
    edited October 2013
    just hooked it up to some **** speaks, and didnt push them.
    Other question, it was an analog meter.
  • zingo
    zingo Posts: 11,258
    edited October 2013
    I also measure DC offset of amps that are new to me, and it's saved me more than once on 80's amps that had +200mv offset!
  • skrol
    skrol Posts: 3,452
    edited October 2013
    The DC offset is the first thing I check on a new to me amp. I looked at a Hafler amp a few years ago that had a way high DC offset in one channel.
    Oh yeah, use a good DMM like a Fluke. Cheap DMM's can be trusted at such low levels.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • scottyboy76
    edited October 2013
    skrol wrote: »
    Did you mean to type "cant" be trusted at such low levels?
    If so i will borrow a better meter, im using a cheap sperry from home depot i have always used to do home wiring projects.
  • lanchile
    lanchile Posts: 560
    edited October 2013
    You can always trust Fluke multimeters. They are the best multimeters your money can buy!. in my book, under 5mv dc offset is very good and 0mv is ideal!!!!
