Looking for Receiver
ferdelance1
ferdelance1 Posts: 7
edited January 2007 in Electronics
I am looking for a receiver that can handle 4 RSi9 speakers simultaneously.
If there is one out there, price is not applicable.
Please advise:
Derek K.
Post edited by ferdelance1 on
  • Burnt
    Burnt Posts: 12
    edited January 2007
    Check Outlaw,Emotiva and Rotel
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    Do you mean LSi9?
    Ben
  • ferdelance1
    edited January 2007
    Sorry about that!
    Derek
  • hangon
    hangon Posts: 228
    edited January 2007
    I have the CineNova Grande 5 channel 300wpc, you can get them for around $2K. Not a bad amp for the price.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Custom Center made out of a RTA15tl
    Pioneer Elite SC-25 Receiver
    CineNova Grande 5 channel Amp
    Klipsch KA-1000-THX Sub Amp
    (2)Klipsch KW-120-THX Subs
    Basement System
    SRS-SDA 1.2 upgraded Xover
    ADCOM GFA 5500
    ADCOM GFA 5503
    Yahama P7000S Pro Audio Amp
    dbx 120x-ds Sub-harmonic Synthesizer
    2-JBL 4645C Subs
    1-Paradigm SW2200 Sub
    Klipsch Reference in wall's
  • ferdelance1
    edited January 2007
    Thank you, I 'll take that under advisement.
    Derek
  • ferdelance1
    edited January 2007
    Thanks much for your help!
    Derek
  • zingo
    zingo Posts: 11,258
    edited January 2007
    My Yamaha has really been good to me. It's a 7.1 at 120 wpc and you can get them and the similar 90's era receivers for a couple hundred dollars. They are solidly built pieces and have never given me a problem. Lately I have only been using the 5.1 with separate amps so I might as well get a preamp at this point. I'm not even taking full advantage of what I have!
  • Porter
    Porter Posts: 34
    edited January 2007
    A really excellent option would be the B&K Components AVR-505 S2 or AVR-507 S2. Absolutely stellar sound and huge current reserve. The 505 is five channel, the 507 is seven channel. Comes with a very good universal programmable remote as well.
    http://www.bkcomp.com/avr507.asp
    This receiver will beat the pants off of any consumer product from Denon, Yamaha, etc. in terms of sound quality but doesn't have HDMI pass through, so if you're looking for a video-crazy product this one isn't it.
    This is one of the few receiver products I've ever seen/used that was truly competent as a high end integrated amplifier for 2-channel. Take that for what it's worth.
    The Outlaw and Rotel mentioned above are also good options... Outlaw makes a great product for the money.
