I need an amp
livewire
I am currently running 7.1 w/rti 10's as mains, fxi5's surround, rti4's back suround, and cs350 for center. I have an Onkyo tx-sr800 at 110w per channel, but I feel these speekers need more power, and would sound beter with more power. I was thinking of the Outlaw 7700 any suggestions. One more thing are the rti10's really 4ohm or are they 8
Post edited by livewire on
the outlaw is a great choice, however ya Onkyo is putting out enough juice for the other speaks minus the fronts, save yourself some money and go M2200s, but if your receiver has the preouts on the back sure, power them with the 7700, you will notice a difference for sure.Shoot the jumper.....................BALLIN.............!!!!!
Welcome to the club Livewire!
Your speakers ARE 8ohm. However, with 1 driver & 2 woofers it takes a lot of power to make them sound their best.
Get any amplifier of at least 200wpc @ 8ohms & you will have plenty of power to make those speakers sound their best. I would get a 7 channel amp & be done with it.
Good bang for the buck is Outlaw Audio. Get a 7700 & you are all set.
Other choices are Rotel, Parasound, Adcom, etc.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
You won't get a higher volume of sound out of the fronts if I use my onkyo to power the other 5 speakers
Not sure what you are asking.
If I run my fronts through a 2 channel amp, and run the rest through my onkyo, won't my fronts put out a louder sound at a lower volume than my others
No, If you were to run a stereo amp to the front speakers and run the rest of the speakers off your avr, you would still set the balance for all your speakers in the AVR (usually +-10 or so db) Just hook up all your speakers, and balance the levels with an SPL meter and you will be good to go.livewire wrote:You won't get a higher volume of sound out of the fronts if I use my onkyo to power the other 5 speakers
The nice thing of getting a 7 channel amp now (even though it would not really be needed for your current setup) is that you could upgrade to any speakers in the future and you know you have enough amplifier power to run them well. If you are planning to upgrade your speakers in the future to lines over the RTi's, I would get the 7700 and not worry about it. If you are planning to keep the RTi's for the forseeable future, get a nice stereo amp to run your 10's off of and run the rest of the speakers off your AVR.
livewire wrote:If I run my fronts through a 2 channel amp, and run the rest through my onkyo, won't my fronts put out a louder sound at a lower volume than my others
If all your speakers were the same you would have a little more of an issue. With the speakers you have you may have to cut the fronts a little but they won't be overbearing.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
actuley i upgraded from my onkyo 787 by adding a 7 channel adcom 7607 at 125 wpc it made my speakers open up and sound great
Outlaws are great! Welcome to the club.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
No doubt the ouboard amp will be an improvement,for sure at louder volumes
It will also offer a big improvement at softer volumes as well.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
IMO...I think Parasound makes a great 5 ch amp..
Works very well with my Denon...
and I/c`s make a difference also
Not trying to open the `ol can-o-worms here guy`s, it`s just that a good sounding amp won`t sound it`s best with crappy I/C`s
Dats awwl....!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
cfrizz wrote:It will also offer a big improvement at softer volumes as well.
Cathy could you expand on this a bit more?
Livewire,
I own the previous version of the Outlaw 7x200watt amp and have had no complaints with it. I was very surprised in how much it opened the sound up from the surround speakers. My RTi12's were actually sucking all the power from my Onkyo NR901 and thus giving little or no power to the surrounds. This was very apparent at action scenes where the sound of items flying around the room suddenly appeared where none were before the amp.
Something else I did not expect is that my system did not get louder. It got clearer. In other words, the music was more articulate. This actually allowed me to listen to music a bit lower since I did not have to crank it up to hear those guitar riffs anymore.
Once the Preamps start supporting HD sound through HDMI 1.3, I will continue that upgrade path and hopefully improve that articulate sound a bit more.
Good luck in your search.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Since the amps are doing all the work and more power mens clearer and better defined sound at any level.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Though I do not want to belabor the point, if your receiver has ample power at a low volume setting to push all your speakers to a desired level, I would think that an amp at those levels would be a non-player.
Of course I have been known to be wrong before...once.
You just did all by yourself HD!:D This was by far the best improvement to my whole system. Until I got the amp, I didn't know that I was missing so much detail or that maybe the details were so muffled!Holydoc wrote:Cathy could you expand on this a bit more?
Something else I did not expect is that my system did not get louder. It got clearer. In other words, the music was more articulate. This actually allowed me to listen to music a bit lower since I did not have to crank it up to hear those guitar riffs anymore.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
cfrizz wrote:You just did all by yourself HD!:D
That is what I get for babbling on like a mad man, Cathy.
Pretty soon I can post questions and answer them myself.
