Confused about Odyssey Mono Extremes
Dot40
As some of you know I am searching for a few amplifiers to power my speakers. I ran across an auction for Odyssey Mono Extremes and am very confused at why these amps are $2500+ for a pair. Their website says they are only 150w rms... Why would you choose this when the Outlaw 2200m is $325 and 200w RMS? Sorry if this is a trivial question
Post edited by Dot40 on
Watts don't mean a damn thing. Base all of your audio buying decisions on how a component sounds, not its specs.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
some amps are more expensive even though they are less powerful.it depends on several things, better build quality, manufacture name, type of amp. a good 35 wpc or 50wpc tube amp can run into many thousands of dollars depending on who made it and the parts involved for example. take a quick look on ebay and you will see names like krell. mark levinson. sell less powerful amps for far more than other higher powered ones. REGARDS SNOWDot40 wrote:As some of you know I am searching for a few amplifiers to power my speakers. I ran across an auction for Odyssey Mono Extremes and am very confused at why these amps are $2500+ for a pair. Their website says they are only 150w rms... Why would you choose this when the Outlaw 2200m is $325 and 200w RMS? Sorry if this is a trivial questionWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Kall Klaus, and make sure that you are in "listen", he' will be happy to answer your question, afternoons are better,,have fun.
