center options for RT55s
I need a center to put with my rt55s. I have been running a pair of RT7s but they are going to go to the rear in a 7.1 set up. (Also considering repalcing side surrounds with another pair of RT7s I have) I assume the cs400 is the one but I have wondered how it would compare to another single RT55? It would probably have to go on its side. Should I just try to find a CS400?
Thanks!
Brad
Thanks!
Brad
Post edited by brussell on
Before I upgraded my RT55s to RTi10s I used a CS 300 with them. Very good match. BTW I still have the 55's and the 300 FS:)Yamaha RX-V1500
Pioneer Elite DV-46AV
Scientific Atalana 8300 PVR-HD
Panasonic TH-42PX60U
Polk RTi10
Polk CSi5
Polk F/Xi3
Polk PSW 350
Mike's IC's
DIY speaker cables (Kimber 4VS Shotgunned) -
brussell wrote:Should I just try to find a CS400?
Yes."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
My inlaws use a CS245 with them and it works well. A 300, 350 or 400 should also match perfectly. I would try to find a 400.
Venom -
Thanks! That was what I was thinking but when I saw a single rt55 going cheap It made me wonder.
Brad -
CS 400,very nice
CS245 works well, as I have used this combo in the past..
The 400 is also a good match , as stated earlierCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
