JL AUDIO 300/4 OR POLK MOMO c400.4?
trustoner
trustoner Posts: 6
edited January 2007 in Car Audio & Electronics
I have polk mmc6500 for my fronts and mmc650 for my rears what amp do you think I should go with JL adudio 300/4 or the Polk c400.4????
having a hard time to decide
Post edited by trustoner on
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2007
    Polk 400.4
    Every bit as good as the JL amp, a little cheaper and youll have an amp that not everybody and their brother has. ;)
  • bknauss
    bknauss Posts: 1,441
    edited January 2007
    The JL is a tightly regulated amp, so you won't be getting the same dynamics as the loosely regulated Polk amp. Just giving you more reasons to buy the Polk, but I'm a bit biased :)
    Brian Knauss
    ex-Electrical Engineer for Polk
  • killerb
    killerb Posts: 390
    edited January 2007
    i like the jl. they are really rock solid amps. not saying the polk isnt, but i just like the jl. i had a 300/4 and just loved it!
    kenwood excelon kdc-x991 h.u.
    Rockford Fosgate 360.3 DSP
    Rockford Fosgate POWER1000 running entire system
    Image Dynamics IDQ12 Sub
    Morel Elate 6 front stage
  • trustoner
    trustoner Posts: 6
    edited January 2007
    what do you mean regulated?? im new to this stuff sorry
  • MacLeod
    edited January 2007
    Brian makes a great point and one that Id forgotten. The JL Slash series amps are fully regulated. That means theyll make say 100 watts at 10-15 volts and at 1-8 ohms. No matter what, theyll make 100 watts.
    The Polks are not regulated. You get more power with more input voltage and so on. The benefit to this is that music isnt constant, its dynamic. So when a snare drum hits like a sledghammer, the Polk will do a better job at reproducing the impact because not being regulated, it will slap it out with more power as opposed to the JL which stays at the same power all the time.
  • Polkemon
    Polkemon Posts: 144
    edited January 2007
    I have the 450/4 with the sr6500's in my daily driver SUV and I have the c400.4 with a set of the infinity Perfects but soon to change to SR6500's in my work truck.
    At first I had thought the JL amp sounded better and stronger but after 400 post to MAC :D . I found that the power being JL 150 x 2 versus Polk 75 x 2 is what I was hearing. I would have to say after some tweeking around the Polk amp sounds Awesome!!! but dont get me wrong the JL amp ROCKS too. It is hard to compar as of now untill I get the SR6500 on the c400.4 then I can compare as to SQ.
    MAC even though the JL amp is tightly regulated then are quite a bit under rated you just dont have to lower the ohm load to get the power and they seem to run a bit cooler then other mono amps I have used even when going down to 2 ohms on it.
    Donny
    NEWEST RIDE:
    2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
    Supercharger Pully Upgrade
    Air Intake
    Mina Exhaust System....
    2007 Chevy Tahoe (Daily Driver):
    Front Doors POLK sr6500
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
    2005 Mercury Mountaineer Premier 4.6L V-8
    All Stock!!! In the process of changing this.
    2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel
  • killerb
    killerb Posts: 390
    edited January 2007
    i disagree with a unregulated amp having more impact. as long as the rail voltage is not exceded a regulated amp will have the same impact. i have used both and have heard no difference in the dynamics of the music or overall sound quality. there are advantages and disadvantages to both designs, but impact and dynamics is not an one of them.
  • MacLeod
    edited January 2007
    Lowering the impedance doesnt make more power. Regulated amps make the same power at 2 ohms, 4 ohms, 8 ohms and so on.
  • exalted512
    exalted512 Posts: 10,735
    edited January 2007
    regulated amps suck the life from your car
    -Cody
  • trustoner
    trustoner Posts: 6
    edited January 2007
    thanks guys for all your inputs i actually just went with the jl audio because i got a verrrrrrry good deal on it..
    do you guys have any suggestions on which amp kit to use?????
  • MacLeod
    edited January 2007
    Run down to your local shop and grab whatever kit they have with the proper size wire. Tsunami, Streetwires, Stinger, theyre all good stuff.
