How to mount my CS1000p
palladia
palladia Posts: 3
edited August 2002 in Speakers
Thinking about buying a new
TV. Unfortunately, the TV does not have
a large flat area on the top, where my
CS1000p currently sits.
I guess that the options are to either
put it over the TV with a bookshelf
or some sort of mounting bracket, or
find a TV stand large enough to
accomodate the speaker.
Putting it below seems too low. Isn't
it supposed to be at ear level or so?
Has anyone found any elegant way to
do so?
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2002
    *IMO*
    Try to get a tv (projection) CCHHEEEmmM! !Hint+Hint! that would be able to accomadate such a HUGE center channel and the problem fixes itself. If not shelves are good. One of those Wal-Mart entertainment centers (all in one units). Actually just put up two L brakets and the CS1000 could BE the shelf. When your center channel is a foot or two longer than your tv ----HHHeeeemmm!
    maybe duct tape or some velcro :lol:
  • scottvamp
    edited August 2002
    Oh yeah- palladia, Welcome to the forum and my sarcasm!
    What is in your setup?;)
  • palladia
    palladia Posts: 3
    edited August 2002
    Thinking of getting a 50" RPTV, but the unit does not have a flat surface at top. It seems that the wall-mounted shelf is probably the way to go.
  • pensacola
    pensacola Posts: 269
    edited August 2002
    Did someone say sarcasm?
    Very quietly, from behind. :eek:
    Give War A Chance
