Aural Ersatz/TAD 803SD any good?
Ricardo
Ricardo Posts: 10,636
edited January 2007 in Speakers
I'll let you know in a couple weeks....
Since I got that pair of ASL Wave 20's from Dennis, I was thinking on getting a small pair of monitors to play with. Saw this in Audiogon, browsed through reviews, and decided that for $159 I had to give them a try.
Anyone heard them????
http://cgi.audiogon.com/cgi-bin/auc.pl?spkrmoni&1169086593
SOPA
Post edited by Ricardo on
    tonyb Posts: 33,072
    edited January 2007
    I have 'em,but not the single driver version.Ok at best in my opinion but for the 100 clams I spent,good enough.Don't expect LSI performance out of them.You do get what you pay for,but worth the dough.Have since retired them to surroud duty.Not all that crazy about them there either.Newer SD version is suppose to be better though.Give them some time to break in and they will open up a bit more.
  • Ricardo
    edited January 2007
    Yeah, this version is supposed to be better as you say; we'll see; has some good reviews, and everybody says that placement is critical, more than with any other speaker. I like the looks though :)
    SOPA
