Polk, please build a LSi11
ivansfo
ivansfo Posts: 145
edited January 2007 in Speakers
I recently went through with a speaker upgrade and in the process, I often thought how great it would be if Polk offered a slim LSi floor stander. Such as a LSi11 with dual or triple 5.25" woofers and the same Vifa tweeter. Simiar to the LSi15 but without the subwoofer since most people now are turning to external subs anyway.
I'm aware some may argue that such a speaker is almost the same as a LSi9 on stands but I prefer the bigger (fuller) sounds of a floor stander.
Anyone else besides me think this product would be successful?
Post edited by ivansfo on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2007
    I'm in.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • szhleppy
    szhleppy Posts: 325
    edited January 2007
    ivansfo wrote:
    I recently went through with a speaker upgrade and in the process, I often thought how great it would be if Polk offered a slim LSi floor stander. Such as a LSi11 with dual or triple 5.25" woofers and the same Vifa tweeter. Simiar to the LSi15 but without the subwoofer since most people now are turning to external enclosures anyway.
    I'm aware some may argue that such a speaker is almost the same as a LSi9 on stands but I prefer the bigger sounds of a floor stander.
    If you just want bigger sound, you might want to peruse the 2 Channel Audio section...there is a new guy going by turbubusa65 posting over there with some great ideas that you could integrate into your system.:D
    tonyb Posts: 33,072
    edited January 2007
    Hey,don't pick on my best bud!!:p
    Please explain "bigger sound"
  • beardog03
    beardog03 Posts: 5,550
    edited January 2007
    Foorstanders generally have a fuller sound....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • ivansfo
    ivansfo Posts: 145
    edited January 2007
    Hope I'm using the right terminology, but bigger meaning "fuller" or not "boxy"? My experience with bookshelf speakers is that you can hear the sound originating from the speakers whereas floorstanders do a better job of filling a room with sound. Though my experience with bookshelves has been only with lower end speakers such as Pinnacle, RTi4, R15, and R20s. Perhaps this is not the case with higher end offerings such as LSi7 or LSi9.
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Triple (or quad) 5-1/4" drivers in a slim floorstander for front stage HT use (with a sub) - I would be all over these.... Build them and I will come....
    Michael
    heiney9 Posts: 25,430
    edited January 2007
    This is definetly NOT the case with the 9's also goes for the 7's but to a lesser degree. The 9's still amaze me. Such a big full scale sound from a small box. Get your ears on them.
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2007
    Floorstanders, in a convential speaker design, are overrated.
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited January 2007
    Michael
    Ummm ... I think they're called SRT's ... http://www.polkaudio.com/homeaudio/products/srtsystem/
  • Holydoc
    Holydoc Posts: 1,048
    edited January 2007
    Please expand.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Three or four per side, not 17.... :)
    Michael
    I have never heard the SRT's but I bet they are awesome. Reguardless of the sound though - the WAF on them is amazingly low. I would stand a better chance putting SRS's in my living room than a complete set of SRT's.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2007
    I have long been telling Polk that if they would build a LSI 9 in a tower speaker that weighs in at around 40lbs that I would be first in line to buy a pair!
    I prefer towers to bookshelves, but I can't manage the weight of the 15's or 25's. I would also have serious placement issues due to the side woofers. since my speakers are confined to only one area with no clear room to go sideways so the woofers would be wasted.
    I truly want to upgrade my Vintage Polks up to the higher level of the LSI's.
    So please Matt, if you build it we will buy!!!
    edited January 2007
    Sorry Cathy but a 40lb floorstander (LSi) isn't going to happen. I understand your issue with floor vs. bookshelf and I was the same way perhaps even more stubborn than you and the LSi 9's are still continuing to blow me away. Throw out everything you know about bookies. If you were blind you would never in a million years guess they are these smallish bookies. I strongly recommend them as an excellent solution for both upgrading and being completely manageble which is perfect for you situation.
    To have the proper cabinet characteristics there is no way to make a dense, colorless cabinet that only weighs in at around 40lbs.
    Rock on Cathy
  • Emlyn
    Emlyn Posts: 4,699
    edited January 2007
    Got to agree a lightweight floorstander is impractical and would be counter to the way Polk speakers are designed. The LSi9's weigh 33 lbs a piece. Some manufacturers have been able to pull off a lightweight design, Spendor comes to mind, but they do so by using two drivers and thin walled cabinet construction. Polk has a tendency to go the other direction--more drivers, heavier construction for less cabinet resonance.
    Ditching the side-firing woofer does seem to be a good idea to me though.
  • PolkWannabie
    edited January 2007
    Michael
    You'd be surprised ... WAF is usually related to the profile that is seen straight on and the SRT's while relatively tall and deep and heavy are also pretty narrow i.e. less then a foot wide ...
    See a typical ( Mine ) front sound stage and how semi invisible they become with a wide screen in between ...
    http://www.polkaudio.com/forums/showcase/closeup.php?userid=54809&pic=137_2_big.jpg
  • Refefer
    Refefer Posts: 1,280
    edited January 2007
    ...and hows it sound?
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2007
    Those speakers scare me (SRTs). . .
    I would be down for an Lsi11. Really like idea of the 9's, but that's another 100+ you'll have to spend on decent stands, and I don't think Bookshelfs on stands ever looks as good as towers. Something without the woofer in a tower shape would be great. Easier to drive than the Lsi15s, too, which would be another good thing.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Refefer
    edited January 2007
    What about those RM8000T speakers that I've seen in the product finder on this here website? Those things are pretty darn narrow and would seem to fit the bill, though I couldn't testify to their sound since I've never heard them. Heck, I can't even find any reviews on them.
    It's F3 is at 55hz and they weigh 42 lbs a piece, which means it was clearly designed for use with a subwoofer, but sounds EXACTLY like what would fit the bill.
    But at 7.5" wide, it should be pretty high on the WAF.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • PolkWannabie
    edited January 2007
    When properly driven the SRT's are effortlessly powerful. The subs are not quite at the level of the better SVS's but they do an admirable job, reach down into the teens, blend very well with the satellites and are infinitely adjustable by remote.
    One of the challenges with them is that there are several different ways they can be wired which result in either 4 or 8 ohm loads all of which have somewhat different sonic characteristics.
    To my ears it would be difficult to do much better especially for HT. One could argue that there are better speakers for 2 Channel but they do a great job with music as well.
  • AndyGwis
    edited January 2007
    Just read up on the SRTs. They may look a bit intimidating to a noob like myself, but reading the overview is just about chubbing me up. Why don't more people have these? I'm guessing the size, $10K is a lot to spend to say you have "Polks", and oh yeah, the size.
    Nice specs, though, and anything with SDA can't be dismissed.
  • PolkWannabie
    edited January 2007
    At $10k I would agree, but these can be had for about a third of their original price when you can find them. You'll see nothing for a couple of months then 2 or 3 sets will come and go on Audiogon or eBay ... I don't know what the production numbers were but I suspect there weren't a zillion of them made. In a room with a good size screen, size becomes pretty much a non issue. They're taller then everything else that Polk made except the SRS's but they're no where near as wide.
  • cfrizz
    edited January 2007
    Well then if you & Emlyn are correct, then I will need recommendations for other speaker brands that are a very close match to the LSI sound that meets my criteria. As well as the weight requirement, it cannot have a metal tweeter!
    I'm a very loyal person, until the brand doesn't have what I require, then I'm forced to find someone else.
    Rock on Cathy
    edited January 2007
    So i take you are NOT even willing to demo the 9's? If you are so loyal i'd say you owe it to Polk and yourself to give them a try :) . Cathy, I know exactly where you are coming from on prefering a floorstander that is why it took me soooo long to pull the trigger on the 9's. I figured i wouldn't be happy unless I got the 15's. I was so so wrong!
  • Emlyn
    Emlyn Posts: 4,699
    edited January 2007
    The trouble with the SRT's was they were too expensive and too far ahead of their time, before enough of those people with enough space and money really got into devoting big money to big home theater systems. Production and dealership numbers were aimed at low volume, but service was great. By the time the market caught up with Polk, the speakers were gone. I've been seeing the number of these on the used market decrease to the point there's hardly anything out there now. Nowadays some people are dropping as much cash on a single pair of speakers as what a full SRT system cost.
    Cathy, most floorstanders worth auditioning weigh around 55 lbs or more. I can't think of a current production floorstander I'd recommend at 40 lbs that would be better than what you already have.
  • PolkWannabie
    edited January 2007
    That's because they've been picked up by Polkie's like me and some others here and we won't be getting rid of them any time soon ...
    I think the original stereo pair was about $7k ... I don't know what the cost of the original center was but I think it's the best center Polk ever made as it is essentially the same set up as the sterro array in the satellites and weighs in at about 40 pounds. It's a real monster even when compared to the CS1000P. I don't have the SRT F/X's but I've heard them and would classify them as ok but nothing special. I do however have a pair of the SRT SDA Surrounds which are quite good which I'm using for rears along with F/X 1000's for the sides.
