SR6500 and Eclpise AMP XA4000
Carsten
The Eclipse amp is a strong one and I am going back and forth in my head on how to hook this up. It is a 4 channel amp and I have only the one set of SR6500.
Here is a link for the amp specs
http://www.eclipse-web.com/amp/xa4000.html
Should I bypass the bulky crossovers and use the crossover on the amp. This would free me up some amp rack space for me which I greatly need.
Should I bridge it and run one channel to each set?
Or should I run just 2 channels leaving 2 unhooked?
Post edited by Carsten on
I would use the x-overs designed by Polk for those specific drivers. They will also give the tweeter a little protection. For power, I would try your last option first and see how you like it.
Why not run all 4ch's to them, it will give you more control....Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
That is a lot of power and could easily rip those SR's to shreds if you bi-amp them and youre not careful.
However, I would say that running them thru the SR crossovers would be your best bet. It would offer a measure of protection and, its an excellent crossover.
Just make sure to remember, that is a LOT of power so use common sense with the gains and volume.
OOpsNEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel -
I have a 450/4 with gain at 12 o'clock froma Nak. MB-x head and 5 Volt pre-outs sending 150 watts per side to my SR6500 through the sr crossover and they sound awesome and so far I have had no issue from the sr's and they play very loud but yet so soft if you no what I mean. Beautiful speakers!!!!!
DonnyNEWEST RIDE:
Air Intake
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
