Polk Audio Speaker SDA SRS 3.1TL
Hi there,
I own this pair of speakers for more than 15 years and still love it today. I am in the process of upgrading the internal wiring of the speaker. Does any one have a schematic diagram showing the internal speaker wiring and where to place the SDA driver.
Thanks in advance.
Dan.
Thanks in advance.
Dan.
Post edited by go2eshop on
Hi and welcome to the forum; you have a great pair of SDA's there. I went through the process of rebuilding the crossovers of mine during the weekend; I'll post details during the day, including the wiring diagram.
Internal Wiring for these speakers is actually not too bad; if you really want to make them jump to the next level, I suggest you change components in the crossovers._________________________________________________
thanks,
It would assist and much appreciated if you can post the internal wiring diagram.
In addition, which components should I be modifing on the crossover to improve the sound, especially a bit more airy and also base.
Is it also worth to upgrade to RD0198 silk dome tweeters as well? and where do I buy them.
Thanks again. -
I believe you can still order the newer tweeters from Polk still.
Here; wiring diagram included there; if what you actually want is the schematics, I can email. As someone mentioned, the tweeters can be bought through Polk, and yes, it is well worth it.
http://www.polkaudio.com/forums/showthread.php?t=47929_________________________________________________
Thanks Guys for your assistant.
I have looked the the forum, I could not seemed to find a specific schematic diagram for SDS SRS 3.1TL.
If anyone have a copy of this schematic diagram, could you kindly forward a copy of email address go2eshop@gmail.com.
In addition, I have contacted polk audio, and we can still get the upgrade tweetie through them.
If I have to upgrade the capacitance and inductance on the crossover, I don't to spend alot, but a reasonable quaility cap. which can improve the sonic performance. Any suggestion ! -
Email sent. You don't really need to upgrade inductors (well..IMO...there have been discussions on this topic). You can change Capacitors and resistor andget a good improvement. Solee caps are cheaper and better than stock._________________________________________________
