Van Alstine Ultra DAC & transports...
pearsall001
pearsall001 Posts: 5,328
edited January 2007 in 2 Channel Audio
I just had to put Frank Van Alstines Ultra DAC to the test. Frank says that any inexpensive DVD/CD player on up to an expensive dedicated transport can be used with his Ultra Dac without noticing any difference. I was using a Consonance CD120 CDP in my system before I upgraded to the Ultra DAC. The CD120 is an excellent sounding player, but the Ultra DAC has taken my system to yet another level. So, for the test, I had a HK DVD/22 DVD/CDP that wasn't being used. I hooked it up & ran it as the transport. I switched back & forth between the CD120 & the HK on & off for over 3 weeks of listening. Well, frank was absolutely right. I couldn't here any audible difference between the two players being used as transports. In Franks literature he states that the design of his Ultra DAC uses circuitry that eliminates jitter which is the big culprit as far as transports are concerned. I certainly can't argue with Frank. The man just builds awesome gear. If any one is interested the CD120 will be for sale shortly. I need to find it a good home.
Post edited by pearsall001 on
  • amulford
    amulford Posts: 5,020
    edited January 2007
    What are you going to do for a transport, Phil?
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2007
    Now give a SonicWave glass-toslink a spin. I'll never go back to an "electrical" connection.
  • pearsall001
    edited January 2007
    Hi Anthony,
    After much listening (over a 3 wk period) I've come to the conclusion that the HK DVD22 player ($150 new about 3 yrs ago) sounds the same as the Consonance CD120 being used as the transport for the Ultra DAC. Frank states that any player will perform just fine as a transport with his Ultra DAC. I must say he is absolutely correct. Hence, I'll keep the HK as the transport & will sell the CD120. The CD120 is just too good of a player & whomever buys it will be very impressed. The Ultra DAC simply took my systenm to another level even over the superb sounding CD120.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2007
    Speaking of jitter, have you experimented with any anti-jitter devices such as Monarchy's DIP or those put out by Audio Alchemy or Theta?
  • pearsall001
    edited January 2007
    Yeah, I did try the Monarchy DIP unit with the HK & the CD120 both taking turns feeding the Ultra DAC. I didn't hear one bit of difference with either player used as transport & hooked up to the DIP unit. Frank states that jitter is handled by his circuitry design inside the DAC. The man knows his stuff!!
  • Lsi9
    Lsi9 Posts: 616
    edited January 2007
    Congrats!
    looks like a fantastic unit, (sound aside) I would prefer a DAC that looks like a stereo component over a small box that looks like an internet router or cb radio. I bet it sounds fantastic
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
