Interesting AVS Thread
http://www.avsforum.com/avs-vb/showthread.php?t=774391
Seems like a nice guy, don't jump down his throat
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP
Post edited by Lsi9 on
I remember when Jim Salk came onto the AVS scene and was promptly told to get lost due to his bullish self promotion of his Veracity speakers. At the time he had only sold 3 pairs and was considered a nice wood craftsmen but not a real speaker maker since he was basically building beautiful boxes and stuffing off the shelf drivers in them without alot of testing and R&D. Since then, he has gathered a decent following, but still comes to defend his product too quickly and with too much gusto for my tastes. BTW he does make pretty speakers.............HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I almost responded to this crap last night. What diatribe. He is completely talking out of his **** about the comparison, making inaccurate assumptions and generally being a pain.
His MTS might sound nice, but in no way compensates for better design, testing, and R&D.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
He is right about the port.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
jakelm wrote:He is right about the port.
He's wrong about port design on the 9s since the majority of the porting is done through the power port in the rear of the cabinet. He is correct about his design being somewhat less placement sensitive due to the sealed box. On his other claims I find it laughable that his off the shelf Vifa driver is superior to Polks custom designed drivers without him carefully studying that specific properties of the Polk and the ring radiator tweeter that Polk uses can hardly be compared to a common "dome" tweeter he so loosely keeps referring to.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
You might not agree, but I believe if Polk used higher quality drivers and crossovers, then Polk wouldnt need to put 3 ports in one cabinet.
But its hard to say which is better. Some think (like me) if you have 2 speakers side by side and speaker A gets the same responce as speaker B, but speaker A doesnt have holes or ports through and through its cabinet and its the drivers producing the Fr and not the box , then speaker A is a better speaker.
Just my opinion.
JakeMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Well you can look at the other side of the coin on the port issue...
More power is left over for the mid range and tweeters instead of having to drive bass woofers.
Sound is sound why should one care if clean bass is produced from a speaker or a port. I disagree with you on ported speakers.
I look for clean midrange and treble in speakers, how low the speakers go is the last thing one should be concerned about.
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
Lsi9 wrote:I look for clean midrange and treble in speakers, how low the speakers go is the last thing one should be concerned about.
I absolutly aggree with you Lsi9. I am saying its hard to say which is better.
But IMO a non ported speaker is my preference because of placement issues.
Take a ported speaker and stick it in a bookshelf, the sound is alot different than if it were not ported. Distance from a back wall, rear port, front firing port. A speaker with no port and is capable of a flat Fr responce can be placed in alot more positons and not loose or gain Fr responce.
So if eveyting else is equal:
Sp A (port) Sp B (nonport)
Fr responce: 1 to 1
Build quality: 1 to 1
Sp placement: 1 to 2
Then Sp B is betterMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
That salk guy is a real monkey comparing his so called salks to polk lsi9s which to me is biased , I know how good those polks are but the salks fail compared to the lsi9s IMOHO.My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
I think what Jim suggested in the AVS thread is the best idea...an A/B test. Anyone done that yet?
Yes I heard them side to side and the polks were alot smoother in the mids than the salks.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Well, there you go!
