Angled sealed box
black magic
is there a difference in performance between an angled box, and a square-shaped box?
Will either of these work for the MM2124?
http://sonicelectronix.com/item_2.html
http://sonicelectronix.com/item_7549.html
its recommended to have an internal volume of .88 cubic feet. but both of these are a little less, would it make that much a difference?
I'm gonna buy a 2nd enclosure rather than build one b/c school is starting Monday and i simply wont have time, plus its not like they're expensive either.
Thanks!
Thanks!
Post edited by black magic on
The shape doesnt matter. All that matters is the interior volume and if its up to spec or not.polkaudio sound quality competitor since 2005
Personally I'd buy the second one you listed. Its made of 3/4" mdf where the other is only 1/2".Panasonic CQ-TX5500 Japanese Tube
PrecisionPower DCX-730 Processor
McIntosh MMC446
polkaudio SR6500 x2
polkaudio SR104DVC x 2 -
lpreston wrote:Personally I'd buy the second one you listed. Its made of 3/4" mdf where the other is only 1/2".
good point! thanks! I didnt even notice that, i assumed both would be 3/4" -
It also appears the 3/4" model has a magnet pocket (of sorts).Panasonic CQ-TX5500 Japanese Tube
McIntosh MMC446
polkaudio SR6500 x2
you get the airspace right and nothing else matters
