CDP output question
phipiper10
phipiper10 Posts: 961
edited January 2007 in Electronics
My cdp has both tube and ss analog outs and also a digital out (coax).
If I were to use the digital out is the tube or ss technology used before reaching this output?
I might not be asking this question correctly or maybe I need to contact the manufacturer? Or maybe the answer is obvious if I had a clue?
I'm not planning on using the digital out. The tube (stock - no rolling yet) analog out is far superior compared to running the coax to the Onkyo. WOW!
The player has been on about 17 hours so far Bada recommends 50 hours.
Thanks,
Rich
Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
Post edited by phipiper10 on
  • Libertyc
    Libertyc Posts: 915
    edited January 2007
    Use the analog outputs because the digital out will bypass the vacuum tube stage.
  • phipiper10
    edited January 2007
    Thanks!
  • Ferres
    Ferres Posts: 310
    edited January 2007
    Choose the analogs specific to the vaccum tubes to get the best performance. It should be indicated at the back which is for SS and which for Vac tubes.
    Enjoy! :D
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    PLEASE get rid of that stock tube. You haven't heard the Bada yet until you do.
    "God grooves with tubes."
  • phipiper10
    edited January 2007
    So much for waiting to change out the tube. Mission accomplished GE 5670 NOS installed. Opening up the player was uncomfortable enough considering how new it was and the money it cost (It was a lot for me anyway).
    Of course now warranty is voided. The original tube was lightly glued in so pulling it out was no fun and a little frightening. It was my first time.:D
    I threw the $20 tube dampner on the new tube too. Whatever, I didn't listen before/after blah blah, it's on there! I hope I don't have to open it up for sometime now, phew.
    As one might expect Tube out sounds best AND LOUDEST. Early I hope it being louder doesn't get me in as much trouble as you found with your cord.. haha!
    Naturally the other ss analog out was next best and lastly the digital out to my onkyo. Only difference on the analog outs was tube out had diamondbacks where ss out had the blue heaven.
    I think the new GE tube sounds better after only a brief listen, I'll be surprised if it continues to improve. Compared to the previous tube my first thought would be that the music sounds more real, lifelike.
    What was clacking in the background now sounds more like wood being struck. Female vocals sound more real too. Everything a bit more vibrant.
  • Early B.
    edited January 2007
    Great.
    Give that tube a little more time to burn in and the Bada will really open up.
