Question about multi channel amp
247yoshi
Okay here's a dumb question.
I have a Denon AVR1803 with 7 channels.
How is the power output for each channel managed by the amp's internals, are they independant channels or one main power source electronically divided.
The reason i am asking, i have just hooked up a Audiosource AMP300 to drive just the fronts...so, is this helping my amp by doing less work or do i now have 2 L&R channels doing nothing (other than delivering the signal via speaker level to the AMP300).
Post edited by 247yoshi on
hey i know its dumb! but someone must know the answer
You are relieving the power supply of your Denon by using outboard power amps, but using speaker level to power the external amps may be a source for higher noise and potentially less quality than the Denon delivered on its own within its power limits. More hum, hiss, etc.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks that's what i wanted to know. I'm using speaker level because Denon AVR1803 has no pre out's. It has zone 2, but i have it set up as 7.1, so zone 2 is used for rear channel. There is a slight hiss from the tweats but i can live with it.
Anyone got any tricks for getting a L + R RCA output from a AVR1803 in 7.1 mode? -
It takes major surgery to access the signal in a receiver prior to the amp section. I'd shine it up and trade up for a higher level model.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thats what i thought, and that was my plan. I am going to go in the direction of seperates for future upgrades.
