Theta Pro Prime IIA DAC on the way!!!
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited January 2007 in Electronics
Months of DAC searching are finally over and it looks like I'll be getting a Theta Pro Prime IIA. Man, oh man am I stoked. I'm hoping to God it plays nice with the other children. Anybody have any experience with this model, or Theta DAC's in general? I noticed madmax has a Theta transport...
Post edited by zombie boy 2000 on
  • Lsi9
    Lsi9 Posts: 616
    edited January 2007
    Congrats!
    Post a pic of it
    Out of curiosity, whats the price?
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
    heiney9 Posts: 25,447
    edited January 2007
    Oh man, be prepared to be blown away. Seperate dac's are where it's at.;)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2007
    I have heard nothing but good things about Theta. Congrats.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • zombie boy 2000
    edited January 2007
    Some pics....
    And a stupid question....
    The button on the right is a phase button which switches the unit from either "in phase" or "inverted". I understand this function as it applies to a subwoofer, but have never seen it on a component. What exactly is its purpose?
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2007
    Some components maintain "absolute polarity" and some don't. My guess is that the vast majority of CDP's would be non-inverting, so you would select "in phase."
  • zombie boy 2000
    edited January 2007
    Thanks for chiming in Steve:)
    So what exactly do you mean by "absolute polarity"?
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2007
    There are preamps that invert the phase (positive signal to the black post, negative signal to the red post); if you had one of these, you'd probably want to use "inverted", though from what I understand there's really no difference in sound, as long as the "absolute" polarity is right (both speakers in phase, or both speakers with inverted phase"
    Anyway, I guess that this does not matter anymore given your Fisher Price new toy....
    SOPA
  • zombie boy 2000
    edited January 2007
    How many times do I have to tell you Ricardo... it's not a "toy". It's an astoundingly sophisticated exercise in high fidelity:D Earing a A+ rating in Sesame Street Quarterly. I think the monkey button is a load of snake-oil, but other than that, it's music to my ears.
    Thanks for clearing up the notion of "absolute polarity". I can see that in my 30 minutes of research, its a topic of much debate. As in, who can hear it and who can't. Why would someone design a preamp to invert the signal? Are amps known to do this as well? The only reason I ask is that the color of the posts on my Monarchy have always been reversed from all other components....
  • Ricardo
    edited January 2007
    My AES preamp inverts the signal in the circuit; don't know why, but it's related to the type of circuit used. Some preamps get the signal back in phase, but it means additional components in the signal path. The instructions of the AES say that you need to connect red/black between the speakers and the amp. I do this on the CArver AL-III's, but don't on the SDA's (common ground requirement). Everything sounds great.
    SOPA
  • zombie boy 2000
    edited January 2007
    I take it you're not a fan Sean:D
  • zombie boy 2000
    edited January 2007
    Just thought I'd provide a quick take on this piece though it has already been replaced (more on that in a bit)...
    Quite simply, this DAC is a stellar piece which worked perfectly within my system. I really wasn't expecting much to be honest. What I did get was a bit more than subtle. The top-end was smoothed out considerably. The soundstage became a bit wider. The separation between instruments entered the sublime. Point blank, everything became a bit more involving -- which really wasn't an issue to begin with. Supposedly this model is renowned for it's tight, controlled bass, but as my system already excels in this area, I didn't really take note of any improvement.
    No A/B comparos necessary... the differences were immediate and especially obvious when the DAC was removed.
    Why? I needed funds for a Pro-ject Debut and Phono Box. However, I do have a Lite Audio DAC-Ah (modded by Pacific Valve) en route, so my DAC journey continues...
    I really miss this piece.
    edited January 2007
    It takes a big man to let go of what sounds like a perfect fitting nirvana piece. Hopefully the unit en route will give the same level of satisfaction.
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    Damn, Zombie, how long did you keep it -- 15 minutes???
    I ain't mad at ya 'cause I've done that a few times.
    BTW -- let us know about the Lite Audio DAC-Ah. Try to hold onto this one for a least a week, please.
    "God grooves with tubes."
  • zombie boy 2000
    edited January 2007
    Oh... it's funding another piece H9, so I wouldn't call me a "big man" so much as a "betting man":D
    I really, really, really am a firm believer in a quality external DAC now. I just couldn't pass up a chance to get my foot into the door of Vinyl. Hopefully, cross my fingers and toss some salt, the Lite Audio will provide just a portion of the Theta's performance.
  • zombie boy 2000
    edited January 2007
    It would have stayed longer. Trust me. I had no intention of letting it go upon hearing it. I just couldn't turn down the opportunity to pick up a Debut, esp. coupled with the opportunity to try another DAC.
    I won't lie though. I'll flip gear without hesitation. I'll always enjoy the music, but the prospect of hearing different interpretations of it is what makes this hobby so much fun.
    Besides EB, I recall a certain tube buffer which never even left the box:D
