SUB to small for opening!!! Help!!!
Polkemon
Polkemon Posts: 144
edited January 2007 in Car Audio & Electronics
I have a pair of the infinity perfect 10.1's and just received a pair of the q-logic boxes for them from Crutchfield (the boxes I received do not come with the qxe ring that the better ones do).
The sub has a smaller Dia. then most subs of the same size so I am running right up at the screw hole on the subs to the opening on the box. The gasket they give you with the perfect is the crapest gasket I have ever seen!!! like 1/8" wide maybe.
The subs dia is 9" and the box is 9.25" being this is the smallest Q-Logic opening on there boxes for sealed 10".
Does any one know where I can get a good wide gasket so I can seal off around the sub or can the qxe ring be bought seperate that will help seal my sub off without having to build a SMALLER TOPPLATE FOR MOUNTING THE SUB TO.
Thanks Donny
NEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel
Post edited by Polkemon on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2007
    Sounds like a good question to ask the folks at Crutchfield.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2007
    I'm sure if you walked around home depot long enough you'll find something you can make a gasket out of.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited January 2007
    I do not think a gasket will help you if the screw holes are already hitting the edge of the box. Sounds like you will either need to make a new baffle for them on the boxes you already have, or get some new boxes with smaller mounting holes.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Polkemon
    Polkemon Posts: 144
    edited January 2007
    I contacted Q-Logic and they are sending me a set of there qxe rings for $12 shipped!
    Thanks for the help
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2007
    I actually wouldve suggest sending them back and running down to your local shop and seeing what they had in the way of pre-made boxes. I bet they couldve fixed you up and probably cheaper.
    But you got it worked out.
  • Polkemon
    Polkemon Posts: 144
    edited January 2007
    I got these boxes for $49 each shipped and all the places around me wanted $75 and up for 5/8 MDF built boxes.
    Thanks for all the sugestions!
    Donny
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • MacLeod
    edited January 2007
    Wow! Thats pretty steep!
    Most of the premade boxes down at my local shops run from $25-100.
    I still say the best way is to build it yourself if you can. Much cheaper!! ;)
  • 1996blackmax
    edited January 2007
    I bought my last 3/4" mdf box for $40 dollars. The one before that was $35 dollars, 3/4" mdf as well. These were from local dealers.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
