r.t.a. 11's ?
turbobusa65
turbobusa65 Posts: 105
edited January 2007 in Vintage Speakers
Hello everbody!! Ok, I got the replacement P.Radiators in, and they have a screw about 1 1/4" long with a washer. What do I do with said screw & washer? and do I need a gasket to seal the speaker or should I use silicon or what? step by step please. Thank's in advance for your input! :D
Post edited by turbobusa65 on
    heiney9 Posts: 25,612
    edited January 2007
    Where did you get the replacements? Are they genuine Polk replacements? I'm assuming they are used as Polk hasn't sold those parts in a long time.
    Have you pulled the other PR's out of the speaker to see how they are installed and sealed? That would be the first step. I used to own RTA 11's but never had a reason to pull the PR's so I don't know.
  • turbobusa65
    edited January 2007
    Replacements came from parts express, since polk does not carry these anymore. :mad: The original radiator's were missing when I got them from a friend, and he threw them away some where along the line!!:mad:
    edited January 2007
    I suppose that's a good compromise. I'm sure they won't be the exact spec., but what other alternatives do you have. Maybe someone will know for sure on the gasket thing. As far as the screw and washer that's probably not what the original Polk PR's had. You'll probably have to rig it somehow. Maybe some of the speaker builders on the forum can give you some idea's about sealing the PR's. A small amount of silicon I'm sure won't hurt anything.
  • turbobusa65
    edited January 2007
    Man!!! these sound very good!!! I was thinking of putting them for sale, but I don't know now. I would like to tighten the bass up some, would adding more wight "screw with more washers" or less washers, help me accomplish this? anybody?
  • turbobusa65
    edited January 2007
    OH! P.R.'s came with gasket's! just did'nt see'um. :rolleyes:
  • Deadof_knight
    Deadof_knight Posts: 980
    edited January 2007
    OK so these arent Polks but replacements either way. Now I might be going out on a limb but. It should be taking washers off to "tighten the bass up" as more weight should make it mushy or loose sounding. F1nut and DarqueKnight or even Htrookie are by far you best information specialists. :rolleyes:
    I just bought replacements for my S8s both passive and drivers you sure polk didnt have them
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
