Need advice on HT speaker system
Hi there, I just have finished my theater room (13x20) enclosed with french doors. Anyways I need advice on this speaker set up. My room will be used for hdtv dish, dvd's, and blu ray. Rti-6 fronts
Csi-5 center
Fxi-5 side rears
Fxi-5 rears or Rti-4 rears ?
Psw-505 sub
Now my powerplant will be the Pioneer Elite Vsx-59txi 160x7 rms. My question is, will these speakers be able to keep up with this receiver and does anyone have this system? I would love to go with the Lsi's but I don't have a 4ohm receiver. I might also upgrade my sub, not too sure yet. Any help would be apreciated. Thanks
Csi-5 center
Fxi-5 side rears
Psw-505 sub
Post edited by rainman on
On the Fxi-5/Rti-4 question, what is the layout of the room? Where are the doors, screen, furniture? The speakers are fine, I doubt that you will ever exceed the power levels that the speakers can handle and keep your hearing. You do have a incredible receiver, do you have the speakers yet? If not I would spend some time in a sound room comparing speakers, you may want to try something higher end.
My room is 13' wide by 20' long, Toshiba 72hmx196 at the front, with the doors on the side away fro any speaker placement. That's what I am kinda of scared of is not enough speaker for my system, keep in my mind I'm using the theater room for.......well a theater room only. Too have big front speakers I think would be a waste, so inturn trying to get the best bookshelve's.
The only place you might be light is in the mains so I'm not sure why you think it might be a waste to have something larger there ...
Try what you have and/or are looking at ... You can always upgrade the 6's and/or sub later if you are so inclined ...
