OK to operate amp on its side??
Ern Dog
Ern Dog Posts: 2,237
edited January 2007 in Electronics
I just spent all my $$$ on a used B&K ST-202 amp and now my problem is where to put it. Of course I'll need to buy an audio rack, but until then- is it ok to use it placed on it's side? Anybody try this before or is it a bad idea? It will arrive on Friday.:D
Post edited by Ern Dog on
  • beardog03
    beardog03 Posts: 5,550
    edited January 2007
    I did it before and was told it was a bad idea, because the heat can`t escape through the venting holes correctly
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    F1nut Posts: 51,776
    edited January 2007
    Bingo!
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2007
    I didn't know there was a correct way for heat to escape through the venting holes? As long as there is proper ventilation, I wouldn't think it would be a problem.
    Mike
    F1nut Posts: 51,776
    edited January 2007
    That's the point isn't it!?! Heat escapes by convection. If the amp is on it's side where is the air flow going to come from?
  • Ern Dog
    edited January 2007
    ****- I'll have to re-think things.
  • MikeC78
    edited January 2007
    Artificially. He could use fans, but I still would never recommend mounting an amp on it's side.
    Mike
  • MikeC78
    edited January 2007
    ^^ Good idea, that too!!
