R15 vs M10
bears
bears Posts: 4
edited January 2007 in Speakers
Already have a pair of M10's for front..CS1 for center..PSW10 for sub. Want to add another pair of M10's to rear but can't find a good price..However, R15's seem to be the same speaker with different grill..Can find them at a great price. Are they compatible? Should I wait for the M10's at a better price??? Or should I add different fronts and use existing M10's for rear?? Syetem used primarily for gaming...Xbox 360..Of course, I'm on a budget...
  • Refefer
    Refefer Posts: 1,280
    edited January 2007
    If you're doing a budget gaming rig where the primary goal is to get decent sound for little money, by all means go with the R15's. The timber will be a little off, but it certainly won't be horrible. The R series in general sounds a little more laid back in the treble when compared to the monitor series, which I prefer, where as the monitor sounds sounds a little too "bright" to me.
    Frankly, if it were me, I'd go for it. It should sound fine enough for what you want. Honestly I doubt you'll notice it all that much, if at all.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
