Does anyone have spare "Polk Audio" emblems?
avguytx
avguytx Posts: 1,628
edited January 2007 in Speakers
I was wondering if anyone might happen to have a spare (or two) "Polk Audio" emblems floating around. I have one that's missing from one of my Monitor 10B's and would like to make them look complete. I am redoing the grills here soon, too. Thanks for any help!
Happy New Year to all!
Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Post edited by avguytx on
  • Libertyc
    Libertyc Posts: 915
    edited December 2006
    Don't have one, but I need one too for a monitor 7s. I might just send you what I have, because I'm in the same boat redoing the cabs and the grills, and can't find another. I might just let the grills be naked with no emblems. Let me know what you think.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I have a couple, but I'm having them dipped in gold, and plan to hang them from a dookie chain pimp style.
    Cheers,
    Russ
  • Refefer
    Refefer Posts: 1,280
    Cheers,
    Russ
    I want pictures :D
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    I have some from monitor 4.6s
    Ben
  • avguytx
    edited January 2007
    Cheers,
    Russ
    I don't know if I'd want something on a chain made of "dookie"! lol
  • avguytx
    edited January 2007
    Are they the type that poke thru the grill frame and have a clip that pushes down on them to lock them in place? Or, are they the the type that have the "one way arrow" that digs into the wood?
    Thanks for the replies!
  • ben62670
    edited January 2007
    They have 2 pins that are about an inch apart. These are the same as the badges on my monitor5's.
    PM me with your addresses
    Ben
  • mikesd
    mikesd Posts: 43
    edited January 2007
    I also have a couple of the two pin type like Ben's that are from a pair of M5s.
  • avguytx
    edited January 2007
    Are they pretty much the same size for all the speakers? PM me and let me know what you want for them. I am going to have to rebuild the grills on my Monitor 10B's because one is broken and the other just looks bad. So, instead of peeling the grill cloth off and trying to fix that, I'll just make some new ones from 1/2" MDF patterned off the old ones. Thanks guys!
    Edit: Here are some pics of the emblem.
  • mikesd
    mikesd Posts: 43
    edited January 2007
  • avguytx
    edited January 2007
    Man, there are various types it looks like! How wide are the ones you sent me a pic of? The one I have is maybe 2.5" in length. On the back side of the stock grill, there is a hole just big enough for the locking clip to go down into and push into place. It might be 1/4" in depth which is half the thickness of the grill. I guess if I'm using something different, it won't matter! Thanks again!
  • mikesd
    mikesd Posts: 43
    edited January 2007
    Mine are 1.5 inches wide and the pins are just a tad over a quarter inch.
