whatgood for mids & tweets?
ch00dlz
Someone told me a multi-channel amplifier is better for the mids & tweets?
Is this true versus the bi-channel amp?
Multi-channel amp meaning 345 channels versus a 2 channel amp?
Thanks in advance!:)
1997 Toyota Supra TT
1993 Honda Civic K20 swap
2004 Honda Pilot EX
I WANT TO BUY:
2004 Honda Pilot EX
I WANT TO BUY:
Post edited by ch00dlz on
Depends on how you want to run your system. If you want to go active or want to bi-amp a component set, then a multi-channel amp will work.
You could also use one if you want to run front and rear speakers.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
1996blackmax wrote:Depends on how you want to run your system. If you want to go active or want to bi-amp a component set, then a multi-channel amp will work.
You lost me...sorry bout that.:o
I just heard that the sound quality is more better with a multi channel amp versus a bi-channel amp which I was thinking of running.
What do you mean by "go Active"?:o Bi-amp meaning 2 channels?
Would that sound more efficient than a multi-channel amp (3ch, 4ch)?
I'm running POLK Momo MMC5250's. They're componants with crossovers.
Thank you for your reply!:)1997 Toyota Supra TT
2004 Honda Pilot EX
I WANT TO BUY: -
You can still bi-amp your 5250's and use the passive crossover that came with them.
Simply run the front channels of the amp to the tweeter inputs of the x-over and the rear channels of the amp to the mids inputs and youre set. This way you can control the tweeters output a lot better by using the front channels gain.
The Polk C400.4 amp would be a great choice for this. Its built specifically to power Momo components. It also has a very good crossover on it and it has the Pre-Eq switch which is a pre-programmed crossover for the Momo componentes.
http://www.polkaudio.com/caraudio/products/c400_4/
$400 at Crutchfield
http://www.crutchfield.com/S-fF1DcY1JSam/cgi-bin/ProdView.asp?g=120&I=107C4004polkaudio sound quality competitor since 2005
Thank you very much for that great information!:D I appreciate all 3 responses as they have provided this noobsta some real information.:D Yes, I was thinking about that C400.4 vs the C300.2 that is why I asked this question....:)
Thank you again. Happy new year to all!:)MacLeod wrote:You can still bi-amp your 5250's and use the passive crossover that came with them.
$400 at Crutchfield
http://www.crutchfield.com/S-fF1DcY1JSam/cgi-bin/ProdView.asp?g=120&I=107C40041997 Toyota Supra TT
2004 Honda Pilot EX
I WANT TO BUY:
