plexi glass enclosure?
joeaudio26
Lets put this idea to rest is it possible to build a enclosure. 100% plexi glass heard this idea before just would like to put it to rest..all info is welcome
Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
Post edited by joeaudio26 on
Yes its possible. Not sure why youd do it tho.polkaudio sound quality competitor since 2005
I assume so people can see your sub could be wrong.Never built a plexi box but heard it's been done wouldnt pressure be a problem?Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
You wouldnt build the entire enclosure out of plexiglass, just one panel like the top.polkaudio sound quality competitor since 2005
MacLeod wrote:You wouldnt build the entire enclosure out of plexiglass, just one panel like the top.
Interesting concept...:)Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest. -
Years ago a friend of mine had a competition setup in his Izuzu lowrider pickup. He had 12, 12" Lanzar subs in the bed in an all plexiglass enclosure (whole bed) ported through to the cab. The materials to make the box was astronomical it was all 1" thick arcrylic from what I remember, just the back of the box (the part you see when you open the tailgate) was $350 and this was easily 13 years ago!
That was one HELL of a system! All Lanzar OptiDrive amps, Lanzar subs, Sony ES 8" Midbass in the doors and 6.5" ES Components, ES Head unit and a Phantom.
And so much dynamat that when the windows were up you would never know there was a system in the vehicle aside from the beads on the rearview mirror jumping like crazy -
I saw a system like that with a pair of 8" subs in what appeared to be a plexiglass bandpass box. This was back in 1991 or so. It was in a Supra and it did get loud.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
