Aperion Audio 632 bookshelf
Chicomoralessxm
Anyone heard this speaker before??? Any thoughts or comparisons?
I'm looking at the Focal 707 or 706 chorus, the rti6, paradigm titan monitor v5
or the 632 anyone been able to compare any of these???? Will be using a hk3480 to power them mainly for music(all genres jazz classical trance. r&b slasa you name it no country though) yes and sometimes loud... any thoughts thanks
Chicomorales:)
Post edited by Chicomoralessxm on
They look decent, but I have not heard them. One of my fears, and it may unwarranted, is that they are not of the same build quality as the "name" brand speakers you are also looking at. My main reference for this statement would be Axiom speakers.
Out of the ones you mentioned, I like the Focal 706's. Actually, I would be relatively satisfied with the Focal, RTi6, or Paradigm. If you don't mind looking at one more speaker, I might recommend the Mordaunt Short 902i as well. From listening experience, I would say they sound a little better than the RTi6, but can't compare them to the Focal or Paradigm speakers.Tschüss
Zach -
Thanks for the input. I'm kinda wondering the same thing when it comes to build quality. I was reccomended to check them out. My prob is I live out side the US!!! I trust polk for sure and i've owned klispch as well. But well I don't doubt the person who suggusted I check them out he's highly regarded I'm just curious about their longterm performance and value......300 for the is tempting. But I like the looks of the Focal or even paradigm over them for sure. And the real wood veneer, or the rti6.Chicomorales:)
