Question about digital cable...
steveinaz
If you get digital cable service, what happens to the other analog televisions you have connected throughout the house? Will they need a special converter to work now?
Post edited by steveinaz on
You will still get all the analog stations without the box.You just need the box for basic and the movie channels,pay per view.You also won't get any digital or HD channels without the box.HT SYSTEM-
lsi 9's -
Cool, thanks man.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
With my cable service, Cox, all channels above 100 are digital and those below 100 are analog. Therefore if you wish to watch channels above 100 on any set, you would need a cablebox (or cablecard if your TV accepts one) to access them.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Thanks fellas.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I think here in Tucson after VOIP is in place, Comcast is going to go all digital.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
anonymouse wrote:... I suspect quite a few people will lose the last reason they stick with cable vs. dish ...
Unfortunately I can't control the weather, but weather can control the dish ...
I used to have that problem with DirectTV. I have Dish Network now and I don't have that problem any more.
