polk rm 6900 surround speaker
mnofsteel34
i had bought the 5.1 setup today at circuit city. They were a open box deal. so i bring them home and hook them up and the left rear surround speaker i think is blown....when i do a test tone on the system they all sound fine and when i get to the left rear it is a whisper...what should i do....do i have a warranty with plok...i don't want to return the the whole setup..what should i do!!!
Post edited by mnofsteel34 on
Depending on your reciever, you should have some sort of on-screen setup function. Withing this, you will be able to adjust and test the volume levels of each individual speaker/channel. This function should send a test tone to the speaker that you believe is blown, which should indicate immediately if the speaker is blown, or if there are other issues within your system (wiring, reciever, settings, etc.)Poulanium
Polk RM6800 set
Denon 1905
Toshiba DVD 9800
Panasonic 42PX60u HDTV -
poulanium wrote:Depending on your reciever, you should have some sort of on-screen setup function. Withing this, you will be able to adjust and test the volume levels of each individual speaker/channel. This function should send a test tone to the speaker that you believe is blown, which should indicate immediately if the speaker is blown, or if there are other issues within your system (wiring, reciever, settings, etc.)
i can set each speaker level -10 to +10
when all other speakers are set to 0 they sound fine...when it comes to the troubled speaker there is nothing...no sound...so i set that particular speaker to +10 and i start to hear something but no where near what it should be...
let me ask you this..if the speaker is blown should it be silent or should i still hear something!!
PROBLEM SOLVED!!!!!!!! I SENT THE SPEAKER TO POLK TO GET REPAIRED!!!!!
