db212-2 amp help
MIwrestler
I just bought a db212-2 and i was wondering what kind of amp i should buy. I noticed some of you said the kenwood amp would be good but is there any amp a little less expesive? Also what kind of power am i going to need for the db212-2 and db690's. So the question is what amp do i need to power the subs and speakers that isnt way expensive?
Post edited by MIwrestler on
Profile. Best budget amps on the market.
For your 690's.
http://www.crutchfield.com/S-joC97t4sei4/cgi-bin/ProdView.asp?g=120&I=489AP600
For the 212-2
http://www.crutchfield.com/S-joC97t4sei4/cgi-bin/ProdView.asp?g=120&I=489AP1000Mpolkaudio sound quality competitor since 2005
Wow! Thanks for the info! But your sayin i need two amps? i cant buy just one bigger one or is this the right way to go? And do you think im gunna need to upgrade the system with any more speakers like tweeters?
MacLeod, thanks for your help. -
You'll need seperate amps for the sub box and 6x9's, since they'll be playing different frequencies. You'll want to low pass the db212 somewhere between 60- 100 Hz, depending on your taste, and high pass the db690's somewhere around 80- 100 Hz.
Hey thanks alot. But do you think those profile amps MacLeod was talking about are good. Because i dont want crap but i really cant spend too much more on my ride.
Profile makes the best $100 amps on the market - but theyre still $100 amps.
If you want quality, youre going to have to pay for it.polkaudio sound quality competitor since 2005
Alrite, i have a little money to spend. But not $500. I want a good amp that will last through, well, all the hell i put it through. LOL! But theres no way i could tell the difference between amps, or, sad to say, anything. So what are my options? what can i choose from? Another thing, i have the 690's and 212's, do you think ill need tweeters, or another smaller speakers set?
$500 for both amps? That aint gonna get you a whole lot seeing that you need a 700 watter.
I found these at Sounddomain.com. Very good quality amps and in the power range youd need. $440 total for both with free shipping.
Kicker 750x1 $322
http://www.cardomain.com/item/KIC06ZX7501
Kicker 70x2 $118
http://www.cardomain.com/item/KIC06ZX2002polkaudio sound quality competitor since 2005
I went searching through the web and ended up on ebay stores and found the 750 for $200 and the 200 for $65. Haha i hope they dont screw me over!
what does bridged power mean? the 690's take 100 watts each and the kicker zx200.4 gives Bridged: 100 x2 at 4 ohms and thats what they take. but what is the bridged output?
