2 SW together?
Tequila
Tequila Posts: 104
edited December 2006 in Speakers
Yes, I don´t know about play 2 subwoffers at the same time. Two SW505 one to the left and the other to the right. Somebody here is playing 2 SW now? What do you think? My Fronts are Rti8.
Thanks.
Post edited by Tequila on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    As a suggestion:
    If you are running both in stereo through the speaker wiring, using the crossover from the sub, place them next to the speakers, as the sub info would arrive at the sub much like that of a full range speaker.
    If you are running them off a receiver through the LFE output, run them next to each other wherever they sound best, since the LFE info is mono in nature and may cancel each other out if distance is too large between the subs.
    Trial and error is the key to any sub integration..............
