Input on this speaker system?
rainman
rainman Posts: 24
edited December 2006 in Speakers
Hey everyone, just wondering if anyone has this speaker set up before I buy.
csi 5 center
rti 6 fronts
fxi 5 rears
fxi 5 side rears
psw 505 sub
This is what I plan on buying, I would be using a Pioneer Elite vsx59txi as my power house. I really would like to upgrade to the Lsi series but I would then need a 4ohm receiver. Any input?
Post edited by rainman on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    That looks like a nice setup. If you're paying full price on the sub, you can probably do better for that amount of money - maybe check out SVS or HSU.
  • Early B.
    Early B. Posts: 7,900
    Yeah, change the sub.
    If you really want the Lsi series and have the funds, then just do it. You'll need separate amplification for the fronts, at a minimum.
    "God grooves with tubes."
  • cstpeter
    cstpeter Posts: 387
    I agree about the sub. In that price range I would also strongly recommend a Martin Logan Dynamo, especially for music.
    And I think your receiver would be able to drive LSi's. This subject has been beat to death here, but I feel a nice receiver like that will do fine--my Denon 3806 drove the LSi9's well. Granted, your not tapping into the full potential of the speakers, but it'll work.
    Have fun.
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
  • RuSsMaN
    RuSsMaN Posts: 17,986
    I think it's a great setup, SUB included.
  • MSALLA
    MSALLA Posts: 1,602
    That set-up looks real nice. The 505's msrp is just under $590.00. For that much you have a few other choices but you'll probably be happy with the 505.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    If space is not an issue I don't think you will regret RTi8's as your mains. Otherwise sounds like a great set up.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • rainman
    rainman Posts: 24
    That is the only thing that is stopping me from purchasing the Lsi speakers, is that I want to make sure my Pioneer vsx59txi will handle all those 4ohm speakers. Here is my system if it does
    lsi 9's front
    lsi c center
    lsi fx rear
    fxi5 side rears
  • rainman
    rainman Posts: 24
    oh yeah as for the sub I think I'm going to take a look at the 12in velodyne's
  • Early B.
    Forget about powering Lsi's with a receiver unless you plan to get separate amps within a short period of time. Otherwise, you'll be wasting money.
    Also, forget about the low end Velodyne subs. If you're not going to go with a Hsu or SVS or something similar, then you may as well stick with the 505.
  • rainman
    rainman Posts: 24
    I guess I should stick to my original speaker plan then. It looks like it's the best I can get except for going with the Lsi speakers. It's just too bad, because the Lsi's really kick ****.
  • PolkWannabie
    PolkWannabie Posts: 2,763
    If you like the LSi's better and assuming your receiver has pre-outs then why not just get a two channel amp to drive the mains and use the receiver to drive the rest ...
    Later you can upgrade to a multi-channel amp if desired and then to a preamp to replace the receiver.
  • cstpeter
    cstpeter Posts: 387
    I think you should get the LSi if you like them so much. I stand by my statement that your receiver (which is $3300 MSRP, 160W) will drive them, at least until you can get an amp. I have a buddy who is driving a full LSi 5.1 system with a Yamaha 2600. It doesn't go into protect mode and he hasn't had any problems. It doesn't sound as good as it could, but it works.
    Get the LSi or you will always be second-guessing yourself!
    Denon DVD-2900
    PS Audio UPC-200
  • GATOR3000
    GATOR3000 Posts: 355
    Just a suggestion…………I would eliminate the fxi 5 side rears and use the $$ to upgrade to Rti8’s up front. Rti8’s would give you a lot better front end in HT application. You will not regret it. The floor standers up front for HT are huge difference from bookshelf speakers. Also, the 8’s would “fill up“ your listening area with fantastic soundstage. If you like music the 8’s are awesome. Rear Rti6’s are more than enough for rear HT “effects”.
    I agree with upgrading the sub, but would do it later. Did have PSW505 sub originally. Don’t underestimate this sub. For the $$ it is not bad at all. Not close to SVS, HSU, ML……….etc……….. but not bad. The 505’s are a bit boomy, but good thunder with HT. In any case you will enjoy it!!!
    Anyway, just my opinion.
    Cheers
    Gator :):)
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • MSALLA
    MSALLA Posts: 1,602
    Cheers
    Gator :):)
    Gator's right. That would sound awsome. I switched from towers to bookshelfs and was not happy. Now I am saving to switch back to towers (Lsi15s) and will be running at least a 2 channel amp for the fronts. The bookshelfs sound great, but lost that big sound stage the towers had.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • rainman
    rainman Posts: 24
    Here is my old system: rti -150's front
    csi-40 center
    fxi-3 rears
    psw-404 sub
    I had a harman avr525 receiver running these impressive speakers. As you can see I has huge fronts but it seemed a little over kill considering my theater was used mainly for film. Thats why I thought this time I would use a very good bookshelf for my fronts, either the lsi's or the rt'6. Also it seemed I needed a bigger receiver to run these puppy's, hence the reason for the pioneer elite 59txi. The system I had was awesome, but I just want to upgrade to little bit better. I think you right if I don't get Lsi speakers I might regret it down the road. But I also wonder that if I got the best in The rti series, that it should also be a pretty damn good set up. Does anyone have the full line of the rti''s.
  • rainman
    rainman Posts: 24
    hey gator your system might be close to what i'm looking for, how does it sound for film, dvd, etc. That is mainly what my theater room is for.
  • danger boy
    danger boy Posts: 15,722
    I like your original speaker plan.. those will mate nicely with each other.. and give you a kick **** system.
    PolkFest 2012, who's going>?
  • rainman
    rainman Posts: 24
    That's what i'm starting to think too, except for upgrading the sub. To me it looks like a wicked speaker system, especially with my pioneer 59txi as the powerhouse. AAAAAAAHHHH so many decisions.
  • GATOR3000
    HT with Rti8's is awesome. As I said you won't regret it. I have used rti8's and Rti6's as fronts even Lsi15's. The 8's delivere more what I want from HT.
    Gator :):)
    Theatre System 5.1
    Original A8T CD
