Sub/Amp
Dex202
I'm tyring to a new sub installed. The amp is a Sony # XM-DS1300PS.
The sub is a Kicker # Comp 05C104. I'm just wondering if this Amp will work for this sub.
The Kicker sub is 4-ohm, RMS 50-150 Watts
The Amp is not Bridgeable, but the wiring instructions show I can hook only one sub up is desired. The problem is that it shows (min. TOTAL 2ohms).
Am I still OK using a 4ohm sub? Any help would be greatly appreciated.
Post edited by Dex202 on
Dex202 wrote:I'm tyring to a new sub installed. The amp is a Sony # XM-DS1300PS.
Don't worry it's fine it's just stating dont hook up anything lower than 2 ohmsWhatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest. -
Thanks Joe! I'm just trying to add a little more bump in my boat. Usually I pay to have these things installed, but hooking up speaker leads should be that challenging. Once again thanks!
