Hooking up Polkaudio RM6750
sc4s2cg
Hi everyone, major newbie here. I'd like to hook up my Polkaudio RM6750 to my computer, and actually succesfully hooked up the Bass. Question is, how do I connect the other speakers? I bought a "Power Limited Circuit Cable" to connect them, and I attached on speaker to the back of the Bass, but sound will not come out of the speaker, the bass has perfect sound.
I connected the same side to the same side (+ to +) and same side to wrong side (+ to -) but it won't do. Is there a specific cable I'm supposed to buy? Also, any reccomendations on any, cheap, "Recievers" to hook up the 5th speaker (center channel)?
Thank you in advance!
sc
sc
Post edited by sc4s2cg on
SC,sc4s2cg wrote:I'd like to hook up my Polkaudio RM6750 to my computer, and actually succesfully hooked up the Bass... how do I connect the other speakers? ...I attached on speaker to the back of the Bass, but sound will not come out of the speaker, the bass has perfect sound.
Does your PC have speaker level (i.e. amplified) outputs? I doubt.
I suspect you connected LINE IN of the subwoofer to the LINE OUT of your PC, and thats not enough to pass the output to the SPEAKER OUTPUT on the back of the sub. The sub has an internal amp, but the satellites dont so you must first pass PC signal through an amplifier or receiver. Check the connection diagram in the manual.
There are plenty of inexpensive receivers on the market for $150-180 an entry-level model from any of the respected audio brands will do the trick (like Pioneer VSX516K, Onkyo TX-SR304S or a prior year 503, etc.), just dont expect too many features at that price. -
Thanks VSchneider,VSchneider wrote:SC,
That's probably what is wrong with my computer. Is there a way I can use my VCR to act as a receiver? And would hooking the speakers up to the tv work at all, as in will I be able to hear my tv sounds in surround sound?
Thanks again!
sc -
A VCR does not contain an amplifier. I think you might find it helpful to check out the education tab (under the Polk banner.) Several of the items there would be useful to you, but the best is probably the home theater guide.
Cheers, JimA day without music is like a day without food.
