Plate Amps
jakelm
jakelm Posts: 4,081
I'm sure this has been covered a zillion times, I appologize for the repeat question.
I just bought a SVS 12.1 puls driver, my incloser is 3.7 cuft downfiring with a 3" port 11" long. My room is approx 1,000cuft. My sub is located in the fron t corner of the living room.
3 plate amps are in question to drive the SVS. 300s BASH from PE. A 240watt Dayton, also from PE. And a Polk 225watt Eosone amp from Ebay. I have had great experience with Dayton and Polk products (drivers, parts), but no experience with Dayton, BASH or Polk plate amps. I do know that with the Dayton and the BASH, you can custom bass boost and custom subsonic filter.
Which amp would be best for my configuration? I did speak to Tom, over at SVS, but he has no experience with these plate amps. He did assure me that anything between 200 and 300 watts, would be plenty. So I have narrowed it down to these.
Any opinions?
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • Jim Shearer
    Jim Shearer Posts: 369
    edited December 2006
    I'm no expert on this, but I just added a 240 w Dayton plate amp to an old, unpowered 10" Visonik sub. The result is quite pleasing. I don't know if you would find any obvious differences among the amps you mentioned. All should have enough power to do the job.
    Cheers, Jim
    A day without music is like a day without food.
  • jakelm
    jakelm Posts: 4,081
    Thanks Jim. I'm just not familliar with plate amps compared to 2 channel amps. But alot of ppl recommend , when going sub, to go plate amp. And with my $100-$150 budget, I just want to make sure I'm not underpowering the 12.1 svs.
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • beardog03
    beardog03 Posts: 5,550
    I believe my SVS has a BASH amp on it
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • jakelm
    jakelm Posts: 4,081
    From what I understand, the guys @ SVS said yes it is a BASH amp, but modified to the gills. So I dont know if the BASH @ PE is a good comparison. But I am leaning toword that (BASH 300s) are the Dayton 240.
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Well....I just bought a Rythmik a350. I hope it works out ok.
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
