Is the Rotel RB-980BX common ground?
Refefer
Refefer Posts: 1,280
edited December 2006 in Electronics
My folks were kind enough to let me pick up a new amplifier for around $300 for my SDAs and I was looking at the RB-980BX. There is a nice one available on agon right now which I'd like to grab, but before I make the pickup I need to know if it's common ground for obvious reasons. I can't find anything in the manual (http://www.rotel.com/support/pdfs/manuals/rb980bx.pdf) to either end.
Any ideas?
Also, if this does happen to be isolated ground or whatever else, any other ideas for a musical amp for around $300 on the used mart?
Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II
Post edited by Refefer on
  • dorokusai
    dorokusai Posts: 25,577
    Got a multi-meter? I doubt it isn't common ground, but a quick check for continuity between the negative binders will create a light bulb upon your head...kinda like a cartoon. Continuity = good.
  • unc2701
    unc2701 Posts: 3,587
    It's got a bridge mono switch; it's common ground.
    Backburner:Krell KAV-300i
