help with sda identification and amp
cluelessinwisco
I have a pair of sda's which I belive are the 2's. 3, 6" mids and 2 tweeters + passive radiator in each. The interconnect cable seems to have 2 round pins + an alinment pin. this confuses me because a tech at polk offered only a two blade or a blade and a pin configuration. I need to identify these so I can get some specs to give to LUMINOUS AUDIO TECHNOLOGY to set up a really sweat passive pre-amp for me. I plan to use a carver m1.5 amp (by the way any one know this amps input imp. and input sensitivity?) don't know how the passive pre will sound but I keep the tone bypassed on my nakimichi av-500 reciver.
p.s. any thoughts on a sub?
Post edited by cluelessinwisco on
Here's a link regarding 1st generation SDA II's. Hope that helps:
http://www.polkaudio.com/forums/showthread.php?t=28024 -
After a little search I think this thread will help you out. Good luck.
Welcomr to the forum.
JT
http://www.polkaudio.com/forums/showthread.php?t=24085&highlight=early+sda+2 -
also.. pictures help ALOT. we can identify them better with a picture of the drivers... congrats on your SDA's.PolkFest 2012, who's going>?
Got it fiqured out these are first run sda 2's one of the links provided earlier helped. now anyone know the specs? I am interested in the spl @ 1w-1m.
